Question about Heater
Old Oct 14, 2011 | 05:30 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I can't believe I never noticed this. The other day, I read a post about running the heat occasionally to dry out the A/C ducts to avoid mildew build-up. I turned on the A/C and put the heat on max. I could hear the blowers running but absolutely no air came out of the vents. I put it on defog and couldn't feel any air coming out of the top of the dash either. The cabin got warmer so I know something is working, but I still think its strange.
Old Oct 14, 2011 | 05:47 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
ya i think you have to change the air direction by pushing the little button with the person on it to direct it at your face.... probably coming out at your feet or something
Old Oct 14, 2011 | 06:07 PM
E350 Sport/ML350RWD
Tried that. When its on Cool- it comes out of the dash vents. When I switch to Hot- I can't feel it.
Old Oct 14, 2011 | 06:11 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
If you remove the battery cover u can see the blower motor to the rear of the plastic compartment. I had put the battery cover on half-azz once and it was weak air, hot and cold. I later figured out a few days later it was that cause I finished my amp wiring and it worked normal again. Also the cabin air filter is behind the glove box, not sure of your miles might be time for a change. I used the fabreeze scented one, smells niiiiiice
Old Oct 15, 2011 | 09:35 AM
E350 Sport/ML350RWD
I have never opened the battery cover, but wouldn't this scenario effect the Cold output too?
If on Cold- high level of air output through the vents.
If on Hot- No air output through ANY vents BUT cabin does get hot.
Old Oct 15, 2011 | 11:10 AM
Samieee's Avatar
C
Where did you get the scented one?
