Where is the blind spot assist sensor?
I'm planning on doing a vinyl wrap of the car but realised if they do the mirrors, it might cover up the sensor. Any idea where the sensor actually is?
I presume the other sensors used by Distronic Plus/parking sensors/etc can all be vinyl wrapped around the sensor or something.
GLC250 Coupe
i know the led where it warns you is a little triangle in the mirror itself.
as for the sensor, it uses the 4 corners of your parking sensor to monitor for oncoming traffic at a certain speed.
If you go into the engineering menu, you can see the frequency and status of the sensors.
Put a small piece of wrap over it and see it the values changes...
hope that helps
hope that helps
hope that helps
hope that helps
Cheers
