Where to put dynamat to reduce drone
Old 02-22-2012, 11:05 PM
nias9527's Avatar
C300 2008
I think the drone comes from rear seat...
how to I remove rear seats so I can put dynamat on...
or where should I put it to reduce drone.
Old 02-22-2012, 11:08 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
The drone actually comes mostly through the trunk tray and the through the rear seat. Placing the dyna mat inside the tire tray in the trunk would be the most common place.
I had planned on doing a bit of dynamatting as well but my rubber trunk mat quieted things down enough for me to strike it off my to do list.
Old 02-22-2012, 11:09 PM
Sportstick's Avatar
Another round of ICE
Lots to read, but check out post #14
https://mbworld.org/forums/c-class-w...d-you-use.html
Old 02-23-2012, 01:08 AM
nias9527's Avatar
C300 2008
Thanks...
I am thinking putting dynamat under the car where the resonator is
is this gonna work??
Will it come off if water gets in??
Old 02-23-2012, 01:15 AM
Mixedfruits's Avatar
E63 Black on Black
not going to help much doing the trunk helps a bit but you dont need to pay so much fo the material they bought. Iforgot what I got but it was something from homedepot like roof seal. looks the same as the dynomat thing and works great. sound is slightly reduced but not too much. I might wrap it twice
Old 02-23-2012, 07:35 AM
Sportstick's Avatar
Originally Posted by nias9527
Thanks...
I'd be concerned about its ability to withstand heat, both for the material itself as well as the adhesive. I really suggest doing the spare tire well first and seeing how you like that change. You'll need to do that part anyway to solve the entire issue as that plastic drum is quite the sound amplifier.
Old 02-23-2012, 11:27 AM
silversx's Avatar
2009 Evo X 420 AWHP, 2012 C250 Sedan
easiest way is to put in on the inside of your race helmet.. unless you're not racing? why do you have such a loud exhaust then?
try this stuff.. works amazing when im at massives and hugging speakers
http://tinyurl.com/6mbtfpg
Old 02-23-2012, 12:13 PM
E63 Black on Black
/\ Biggest troll
Old 02-23-2012, 12:18 PM
silversx's Avatar
Old 02-23-2012, 01:08 PM
SPONSOR/MBworld Guru
AZN Optics's Avatar
Agree with others, if you're going to do this, #1 spot to start in the trunk by the spare wheel. Opening it up, it becomes very apparent that it's the only spot that doesn't already have any built in sound dampening from factory as it's just a piece of plastic. Cover that section up and go from there. I threw a layer of Second Skin Damplifier Pro followed up with Luxury Liner Pro and that made a world of difference.
Old 02-23-2012, 01:57 PM
nias9527's Avatar
C300 2008
Thanks guys....
Okay I will put in the spare tire trunk first....and see how it's working out.
Btw...I ordered the dynamat door kit is this enough to cover all of the spare tire trunk?
silversx...it's not that loud LOL...
Old 09-19-2017, 11:14 AM
nkucz's Avatar
2013 Mercedes-Benz C300 4matic Sport
Hate to bring up such an old thread. However, I'm currently dealing with some drone issues on my 2013 C300, it sounds great and is bearable on regular roads. However, on the highway it can become quite brutal. How much did Second Skin Damplifier Pro and Luxury Liner Pro help drone? I can tell that the drone is coming from the trunk tray/ back seats.
Old 09-19-2017, 12:10 PM
AZN Optics's Avatar
Made a pretty significant difference for me and was well worth it. Just make sure you apply it properly.
Old 09-19-2017, 12:24 PM
nkucz's Avatar
Awesome, any advice from applying it properly ?
Old 09-19-2017, 01:12 PM
AZN Optics's Avatar
Just follow the instruction. Get as much surface area as possible. Measure twice, cut once.
Old 09-19-2017, 01:16 PM
nkucz's Avatar
Thanks! Hopefully help make the drone bearable on the highway.
Old 09-19-2017, 04:36 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi
I removed the covers for the B pillar and did that as well, sealed up all the holes and noticed a difference straight away.
Apparently the W204 face lift is a quitter car it would be interesting to learn how they achieved that and where the sound proofing was added.
Old 09-20-2017, 12:05 PM
nkucz's Avatar
One more question, how many sq ft. of Damplifier Pro did you use? Can't decide between 13 sq ft. or 20 sq ft. Would obviously prefer to spend less.
Old 09-20-2017, 01:13 PM
AZN Optics's Avatar
Do be honest, can't remember. Just measure out the trunk space and see how much you'll need.
Quick Reply: Where to put dynamat to reduce drone
