I just Installed my new Wheels/Tires yay! now whats the right PSI?
2012 E350 4-matic SPORT
Edited with new info
new Tires came psi Maxed Out at 50.
What psi do i need to have them at?
my stock 17 inch rims with the continental tires was 30 psi in the front and 35 psi in the back.
This new wheels/tires are 18 inch with 4 225/40R18XL 92W BW YOK YK580
The tires say max 50 psi but i don't know that is what i need for normal driving
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Great looking wheels. Per MBUSA, label on fuel filler flap for normal usage (you and a guest/light load/normal driving). Label on driver's door opening b-pillar for max load.
The tire pressure doesn't know or care if the wheel is stock or aftermarket. His tire size is not extraordinary in any way. The label still applies. Overinflation burns out the center of the tire contact patch faster and from prior postings, we know the OP wants and needs these tires to have a good long tread life.
30 years in the auto business includes quite a bit of research, thanks. The max pressure of 50 psi on his sidewall is NOT an indicator in anyway of recommended pressure for daily use and is not relevant to his question. Given the similar size, the pressure recommended by Mercedes still governs for optimal chassis performance. Vary at your own risk.
so the sticker on the side of the door that has the psi! I had assumed that the stickers on the door and the gas tank door did not apply to the new wheels/tires because of different size.
I am confused as hell.
Tires came psi Maxed Out. What psi do i need to have them at?
my stock 17 inch rims Were with the continental tires was 30 psi in the front and 35 psi in the back.
The new tires say max 50 psi but i don't know that is what i need for normal driving
OP: With your recent edit and now that we see your labels, we know you have changed from 17" to 18", so I would ask someone with 18" to inform you of their label values. I also had, but still have 17", or I would offer my information. 50 psi is not the answer, and there is no formula to subtract from max to get the right reading. The 18" label on someone else's car will be helpful, and will likely show 1 or 2 psi higher than yours.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
When I changed from 17" to 18" (B4 delivery), I purchased the correct 18" label for the gas door. The B-post label cannot be changed, BTW.
so I'm getting many different numbers. i don't have a stagger setup so all tires are the same size. so should i do 35 all around, or 38 all around ?
2011 C300 Sport, 2007 Nissan Titan Crew Cab
The numbers you are getting from people with the / in the middle is a high low range, not front to back. I would suggest starting with the higher number and letting a little air out if you feel the ride is too harsh for your liking.
And, your new wheels/tires came with 50psi so that you could lower them to whatever you want without needing an air source. Should be obvious.
No one would ever run them at max pressure.
Keep in mind that the pressure will vary about 1psi for every 10 degree Fahrenheit change in outside temperatures. We recently went from 40s to almost 80, so my tire pressure increased about 3 psi. So, with the changes the country is currently experiencing while we transition from Winter to Summer (what happened to Spring?!?!?), it's good to have a handy gauge and check periodically due to climate, on cold tires first thing before the morning drive, as well as for normal monthly tire maintenance.
Thank you for your kind support.
Bottom line, I think for daily use on passenger cars, nitrogen sellers may have an overinflated opinion (sorry) of the value. A handy gauge and a simple one-time $40 compressor (on Amazon) for home use, or a nearby gas station really does the job.
Some homework reading:
http://www.getnitrogen.org/sub.php?v...eratureeffects
2016 C63, 2009 C3004M
2009 C300 4Matic Sport 17". Driver's door pillar says 28/33, fuel door suggests 30/35. I did go with 33/38 when I moved to C63 18" rims, which caused terrible wear pattern on the rears (due to over inflation). Unless you normally have rear passengers, make your own rules based on the average load conditions. I'm running at 31/34 at the moment being the only person in the car over 90% of the times.
