Wheel Sizing for C350
Old Mar 29, 2012 | 12:33 PM
chewychiu's Avatar
2013 GL450
Need help! Anyone know if I can fit these on my 2010 C350?
8.5X19 front 10X19 rear
If so, what size tires should I get to avoid any rub? Thanks in advance!!
Old Mar 29, 2012 | 12:37 PM
mhad2480's Avatar
2011 C300 Sport, 2007 Nissan Titan Crew Cab
You need to find out/post the offsets to answer that question.
Old Mar 29, 2012 | 12:43 PM
chewychiu's Avatar
2013 GL450
Sorry, I think the offsets for the wheels are 40 front 60 rear.
Old Mar 29, 2012 | 12:51 PM
C300Man's Avatar
C300
Follow this thread for tire size and offset.
Old Mar 29, 2012 | 01:00 PM
mhad2480's Avatar
The rear offset sounds a little high, but I'm definitely no expert. Jimmythegreek seems to be one of the resident experts on this forum, but if he doesn't chime in search the above thread for info. There are plenty of people running staggered set ups here with most running 8.5s up front and 9.5s in the rear, there are some running 10s in the rear. It all depends on the offset, tire size and what suspension you are running.
Old Mar 30, 2012 | 12:34 PM
chewychiu's Avatar
2013 GL450
Will these fit? The offset is 35, might be too low?
http://www.ebay.com/itm/BRAND-NEW-ME...e937a2&vxp=mtr
Old Mar 30, 2012 | 12:40 PM
SAMHATTI's Avatar
dont waste your time you need greater then a 45 in the rear and atleast a 40 up front
Old Mar 30, 2012 | 02:35 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
you got my pm back w tire size to the 19s you posted. as far as the link above our cars can run +35mm offset at STOCK RIDE height only, unless your willing to do some expirementing and tweaking. They need to be skinny brand tires on those wheels, the tires on there now will rub. It would be 225/40/18 front and 255/35/18 rears to clear. U cannot drop or it will rub. With regular width/brand tires you would use 215/245 in place of above tire sizes. U will have flush fronts and a little poke out back, about a 1/4" inch. They make those same exact wheels in a replica for about 800ish and they are 45/45 offset in 8.5 and 9.5 in both 18 and 19 inches. thats your best bet if you like that look. check out powerwheelspro in the classified section or search "w204 wheels" or "C300 wheels" on ebay for more choices.
Old Mar 30, 2012 | 04:20 PM
chewychiu's Avatar
2013 GL450
thank you jimmythegeek!
