Old 06-04-2015, 07:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
DIY - Brake pad and rotor replacement. W204 C300 C250
Old 09-02-2012, 08:53 PM
ggms16's Avatar
2009 C300 4Matic Sport
Hey Folks. I recently replaced the rotors and pads on my C300 4Matic and thought it would be nice to share since there's no specific DIY around for this, at least not that I'm aware.
Difficulty: Easy
Time: 15min each (I'm young but have a hip prosthesis so you might be able to do that faster)
What you will need:
1. Brake Pads - PN 005 420 12 20
Note 1: as for the brake pads, I stopped using OEM's and went akebono ceramic. Why? I Hate the brake dust everyday more and the Akebonos has been very reliable to me lately.
Note 2: These pads will fit only C300 and C250 as far as my knowledge goes.
Note 3: Make sure the sensor is included, if not, find it with the PN 2115401717
2. Brake rotors - PN 2044210912
Note 1: I used Zimmermann, bought them at autohausaz for 76$ each, I was told they are the same as OEM.
Note 2: These rotors will only fit C300 and C250 Sport models as far as I know.
3. Hammer
4. 17mm Wrench, 18mm and 13mm socket
DIY - Brake pad and rotor replacement. W204 C300 C250-dados.jpgDIY - Brake pad and rotor replacement. W204 C300 C250-wrench.jpg
5. A ratchet, if its long or extensible it will be much better
6. A T-27 socket.
7. Any kind of compression tool. Something like this:
Procedure:
Raise your car, take the wheel out and put a jack stand under your car to hold it, never ever trust in your jack to hold your car.
I will highly recommend to turn the steering wheel to the oposite side, so If you are working on the driver side, turn the steering wheel as if you will make a right. It will leave much more space to work.
1. Proceed to loose the lower 13mm bolt you will find behind the caliper.
Just loose it a little bit, then using the 17mm wrench hold the nut between the caliper and the rotor and take the bolt out using the ratchet.
2. Raise the caliper arm and take the old pads and sensor out.
3. Now loose and take out the bolts that hold the brake caliper base to the knuckle. These are 18mm bolts, really long ones.
Now that you have the complete caliper assy apart, let it rest on top of something, so you don't stretch the brake lines.
4. Using your wrench and the T-27 socket, release the only screw that holds the rotor with the knuckle.
5. Now using your hammer, hit the rotor from behing to release it from the knuckle. It might be stuck to it, if you can't remove it, use WD40 in the wheel bolt holes and let it stand for a few minutes and try again. I only needed to do this on the passenger side.
6. Now proceed and install your new rotor, put back the T-27 screw in place.
7. Now using your compression tool, figure out how to push the caliper piston back so you can fit your new and fat pads to it.
8. Install back the caliper by holding it with the 18mm bolts you removed before. Install the pads in it and it should be looking like this:
9. Now close the caliper arm, make sure you opened the piston enough so I can fit with the new pads, put the 13mm bolt back on the caliper and use the 17mm wrench to hold it as you tight the bold with the ratchet. Then replace the sensor by pulling the old one out and inserting the new one.
The brake pad has a tiny hole where the other extremity of the sensor should fit in.
10. Mount the wheel back on and you are ready. Go for a test drive.
I hope this will be useful for you guys out there, any question, comments or recommendations are welcome.
uzziiiii (04-16-2024)
Old 09-02-2012, 09:09 PM
dgghostkilla's Avatar
2012 E350 4-matic SPORT
Good ****. I found a video that shows how to do the rear ones and posted it on a thread I started a few days ago. I'm replacing all rotors, brake pads and painting the calipers. Im just about done with the rear wheels and your post has just complimented me so when I start on the fronts tomm. Sweet stuff.
I went akebono route as well but different rotors.
Old 09-02-2012, 09:11 PM
ggms16's Avatar
Originally Posted by dgghostkilla
Good ****. I found a video that's shows how to do the rear ones and posted it on a thread I started a few days ago. I'm replacing all rotors, brake pads and painting the calipers. Im just about done with the rear wheels and your post has just complimented me so when I start on the fronts tomm. Sweet stuff.
Glad to hear. Post your pictures after you painted your calipers.
Old 09-02-2012, 09:39 PM
https://mbworld.org/forums/showthrea...21#post5342621
Old 09-02-2012, 10:23 PM
xzotik1's Avatar
C300 AMG SPORT
I am also a huge DIY'er...thanks for posting this. I have one question though.What purpose the sensor serves.
Old 09-02-2012, 10:26 PM
the pads get thin to the point that eventually they will expose the sensor to the rotor. once the rotor has contact with the rotor it will activate the "check your brakes light"
Old 09-02-2012, 11:15 PM
ggms16's Avatar
AND...
When you see the "CHECK YOUR BRAKES" light in your dash, the sensor is already dead. They live to sacrifice, when the light's on, the sensor is already dead and you need to replace it.
Old 09-03-2012, 10:21 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
how many miles do you have when you changed your pads and rotors? I just did my own oil change today so my next project is the brakes
Old 09-04-2012, 05:03 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Did you bleed the brake lines? I keep seeing Do-It-Yourself links to Brake Pad/Rotor replacement but no one indicates they are having their lines bled.
Old 09-04-2012, 09:53 AM
I am all done with my rear rotors, brake pads and caliper painting. its time to study up your thread and begin my fronts in a few hours thanks
Old 09-04-2012, 08:22 PM
spencer3's Avatar
C300
Got mine done last week to. Makes such a difference.
Attached Thumbnails DIY - Brake pad and rotor replacement. W204 C300 C250-20120825_140958.jpg
Old 09-04-2012, 09:47 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
why will the akekono pads not fit a C350?
does c350 have bigger calipers?
Old 09-05-2012, 09:37 AM
dansonchan's Avatar
2009 C300 Sport 4MATIC™ Sedan
What kind of paint u use for the black out and how many coat u paint on it?thanks
Old 09-09-2012, 03:45 PM
ggms16's Avatar
I don't see a reason to bleed the brake lines when you are just changing the pads and rotor.
ggms16's Avatar
Parts number are different, so I guess they should be bigger.
Old 09-09-2012, 09:14 PM
I had plenty of time since I have two cars. I did 5 coats on each (not that you need that many maybe just 2-3)and I bought that dupliColor caliper paint. You can get it at amazon, auto zone, pep boys etc. They have many colors
Old 09-09-2012, 09:20 PM
E350 Sport/ML350RWD
You should actually be draining and refilling ALL of the fluid every 2 years according to MB.
Old 01-31-2013, 10:05 AM
sublimobile's Avatar
C300 4MATIC AWD
Hi, thanks for the great write up and pictures. This helps a lot.
I have a few questions. I have a 2010 C300 4MATIC. Since it has the sensors, how do those sensors let you know your brake pads are low? Does it flash up on the main dashboard screen?
Is there any chance my car does not have the brake pad wear sensors? I believe they do, but it's tough to have any certainty when it comes to a Mercedes.....no manuals!!
Thanks again.
Old 02-02-2013, 01:55 PM
NorcalMark's Avatar
C300
tire rack says the akebono is 3 out of 5 for stopping power? I find this disturbing. Shouldn't you want 5/5 for stopping power
Old 02-02-2013, 05:37 PM
Sportstick's Avatar
Another round of ICE
What is the basis of the scale? Is a 5 a metallic pad for the highest performance settings for a race track? What is the OE pad....a 2? I don't know. I can tell you after running several cars on Akebono EUR pads for a couple of years, their performance is excellent and I would not revert to OE pads.
Old 02-02-2013, 07:05 PM
NorcalMark's Avatar
C300
Im not sure sportstick. I would guess for normal driving(not racing) that would be fine. *shrugs*
Old 04-06-2013, 03:17 AM
Cillys's Avatar
2011 C300 Sport 4MATIC
What brand and from where did you get the caliper paint? Thanks
Old 06-21-2013, 04:10 PM
nyca's Avatar
I just did this job on my car, this is a good DIY - one note, the 17mm wrench you need for this job has to have a slim head, because the bolt has a captive washer that only allow a narrow thickness wrench to grab the inside caliper bolt head. The rear caliper bolt setup is much better engineered than this setup on the fronts.
Old 07-31-2013, 01:00 PM
Smithwds's Avatar
2009 C300 Sport 4Matic
Excellent tutorial, easier to replace than a number of other cars. I wish Mercedes and others would eliminate the easy to strip Torex screws. Thanks
Old 08-28-2013, 01:52 PM
JungAhn's Avatar
C300
Brake Sensor
I just ordered new OEM brake pads for the front and it only came with 1 sensor... Is this normal or do i need to buy another one ?
Quick Reply: DIY - Brake pad and rotor replacement. W204 C300 C250
