W204 Possible to upgrade from 5" OEM Display to 7" OEM Touchscreen Display?
2 Attachment(s)
i currently own a 2009 C350 and only have the OEM 5" in-dash display without NAV.
my question is, is it possible to upgrade to the OEM 7" Navigation System Display (part no. A 204 820 46 97 9F 45) as long as i also upgrade the head unit below to the matching OEM Navigation CD Radio Head Unit Changer HDD? what other parts might i need to make sure i don't lose any of my original functions (i.e. steering wheel controls, center console scroll wheel, etc.) |
Nice thread, I have got the same problem.
here's a thread from the other forum on the retrofit
http://www.benzworld.org/forums/audi...4-c-class.html |
You do know that the 7" display isn't touchscreen either, right?
You just buy this, take the old one out plug the new one in, then have the dealer to program the car Navi = Present. It is NOT touch screen tho.
http://www.ebay.com/itm/Mercedes-C-class-W204-Comand-NTG-4-sat-nav-HDD-navigation-system-/271217694129?pt=UK_In_Car_Technology&hash=item3f25d595b1 |
Originally Posted by MDMercedesGuy
(Post 5672194)
Originally Posted by nismosr
(Post 5672174)
i recently just upgraded my 2011 c300 with the 7" screen, what snowmuch said is completely wrong in regards to what needs to be purchased. here are the list of parts that is required to do the retrofit
204 870 28 51 SWITCH FOR CONTROL DISPLAY 001 A 204 830 41 54 9116 AIR NOZZLE CENTRAL 001 A 022 545 74 26 CLUTCH ANTENNA CABLE 2-PIN 001 A 211 820 00 88 EL. CABLE ANTENNA CABLE ADAPTER 001 A 204 540 97 06 WIRING HARNESS 001 A 204 440 95 32 ELECTRICAL WIRING HARNESS OPERATING UNIT TO CENTRAL DISPLAY 001 A 211 984 04 29. X2 BOLT MOUNTING OF AIR INTAKE M5X16 001 A 204 832 12 45 AIR DUCT AT CONSOLE LEFT 001 A 204 832 05 45 AIR DUCT UNDER CONTROL UNIT 001 A 204 832 10 45 AIR DUCT AIR INTAKE,BOTTOM 001 A 204 832 06 45 Air duct A 204 906 01 15 FAN 001 A 001 820 76 75 ANTENNAGPS A 204 820 46 97 9F45 MONITOR 001 A 204 900 96 06 CONTROL UNIT 001 then perform the following in order http://ww2.justanswer.com/uploads/CH...ess_comand.pdf http://ww2.justanswer.com/uploads/CH...for_comand.pdf http://ww2.justanswer.com/uploads/CH...ion_system.pdf |
after the above, you'll also need to take car to dealer or anyone with a star diagnostic tool or even aftermarket tools that can program the needed scn coding and update datacard on vehicle. optional to update firmware on your control unit to the newest verson then update map verson as well.
oh and after install that comand, u'll also gain voice controls for your navi :)
Originally Posted by Seraphim
(Post 5675600)
Originally Posted by snowmuch
(Post 5676463)
uh? That's what I did and everything works fine. :crazy:
(Post 5672465)
(Post 5675600)
Originally Posted by caligreenzzz
(Post 5681801)
please dont listen to this uneducated person....i did this mod years ago, and the dealer does not need to program anything....its plug n play after redirecting some of the wiring....
Originally Posted by vic viper
(Post 5681801)
the IC need to be SCN coded for this. The code for your old system need to be removed (523 for Audio 20) and the code for COMAND with (512) or without (527) DVD changer needs to be added, then the COMAND unit and the IC need to be SCN coded, this can only be done using a valid star diagnosis tool.
Oh I love the irony. I have to prove you wrong not once, but many times from other threads. But then again you're the same pathetic idiot who said MB looks like a 4x4 :rolf: |
1 Attachment(s)
(Post 5681874)
Attachment 377579 |
It all depends on your cars as well as the HU current setup, ie. if MOST is activated in any side problems can occur, it may also work from the getgo but thats not the case for everyone.
In any case I feel that I would want my car correctly programmed and coded to eliminate future problems and make any kind of diagnosis troubleshooting easier. |
(Post 5681929)
problems can occur
Most common is that HU is shutting down, often in combination with opening or closing front doors.
(Post 5681938)
(Post 5681927)
(Post 5681943)
do you have a link???
A link to what?, why is this so important for you? |
(Post 5681957)
I was looking into to this when I first purchased my 2011 c300, I was referred by MB dealership to an authorized shop that deals with MB and they quoted 3000$ for the unit and 2500$ for installation mainly due to some sort of computer upgrade? Sounds like too much trouble for that beauty of a screen. Next time just going to get the Premium sound package
your guys are charging you too much, its really not that costly, i got my whole unit done for a lil over 1500. just go on car-parts.com and find a used unit and display. as for installation, take it to any body shop to install then finally, take it to that "authorized" shop to have them program it.
for the installation, follow my instructions in the comments above |
