will rims from 2008' fit on 2013'?
1 Attachment(s)
Kinda similar to the other thread I made about grills
I found a set of 18" rims on craigslist I want to put on my car These are the specs. 225/40zr18xL 92wm+s extra load Radial max load 1400 pounds 50psi Brand- tiger paws They were on a 2008 c class I wanna put them on my 2013 C class 4Matic sport All the same size, not staggered. |
Originally Posted by mikec732
(Post 5752474)
I dont know the bolt patern.
What do you mean by thin? Forgive my ignorance, ive never done this with wheels before. |
(Post 5752499)
Originally Posted by dolvio
(Post 5752505)
Send me the link to the ad buddy... Let me read it. You need 5x112 bolt pattern and the right offset for it to work... 225 tires are thin. They are probably what are on the front of your car now. Some guys on here run 265/275 on the back...
My first post had all the info that was offered in the ad. im assuming that because 08' uses 5x112, which is what these were on, they would fit my 2013 If the tires are the wrong size I could change em, as the rims are at a great price of $600 |
If they actually were on a c class then they would fit. However, without a few more details like rim width, offset and such I would pass on them.
Good luck, Adam |
they will fit with that bolt pattern...but without offset and tire sizes it might look terrible as far as sticking out too much or not enough...im running a 245 up front and a 275 in the rear of my 08
As said if they were on an 08 they will work on your 13. The wheels I have on my 13 were on my 11 and 08 before.
