Rear Camera for Audio 20...?
w 204
Hello...
At first sorry my english...I have a problem. My car is w 204/08 and in it is only Audio 20 whitout APS... etcetera. Is it possible to install rear camera in it?
Have anybody installed Rear Camera in it..? And if...so what kind Camera and...i think that it needs somekind Video Interface too...???
kindly Jussi from cold Finland
w 204
The picture rolling etcetera...and after while computer notifyd, that presure of tires is not ok...so it is item is very labile.
The harnes made ok..
kindly Jussi
w 204
do you know how the car measures the presure on the tires? via its traction control system.
and on a final note, i have this veryon module in my car with the NTG4 COMAND, 3 camera's connected to it and all work fine, just had to select the correct dipswitches for the higher resolution
w 204
huh? this item is connected between your audio 20 unit and the display, it has no connection let alone interference with the board computer.
But now I know that it was coinsidense...when the interface was installed..after few days the front sam preaked down..so i think, that with this episode was some common.
So after installing the picture was not ok..it rolling etc.
I tryet allso different combinations whit dipswitches..but no help.
thanks. Jussi
