URGENT! Need some feedback please :)
Hey everyone I have a 2008 C300 and it's due a service A at 42k miles. It's about 15 days past service day because the Mercedes Dealership here scheduled it so far out. Well tomorrow is the day, and the service advisor told me that it's gonna run 803.00 because at 45k it will need a transmission flush, on top of the regular service A.
To me this sounds a little expensive for a regular service...I called the other dealership in Georgetown ant they said 750..
Is this right? Should I cancel and just do everything on my own? The transmission flush is said to be around 400 after taxes by itself.
Yes from my understanding that is the price, but I don't think service A has transmission flush included does it?
I called around, Georgetown Mercedes quoted me 750 total.
So basically...service A + transmission flush = service B .... right?
Just a breakdown of what's all included in A & B Services.
A SERVICE (~ $205.95 + tax) :
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
* Not included in total
clamps
- Brake inspection
- Function check
clamps
- Brake inspection
- Function check
1 Post
'08 C300 4Matic Sport, '02 530i
When you're there, make sure they do it the right way and drain all the fluid, not just from the trans but also from the torque converter area. If they don't, they'll only be replacing half the fluid, and that's not right, but most dealers are lazy and don't do it right.
No. Transmission fluid change is separate from Service A or Service B. You need to have it done at 40K mile intervals, that's why your dealer is telling you to get it done.
I guess my question is, how can I tell they did it the right way after I tell them to drain all the fluid from the torque converter area also?
1 Post
https://mbworld.org/forums/c-class-w...ce-thread.html
They outline the proper procedure. Print it out and give it to your service advisor or technician.
Awesome, il make sure to tell them before hand and check the invoice afterwards also. So 700-800 is a good price for Service A + Transmission ?
1 Post
Not really, but I've seen other dealers charge similar.
My dealer charges $200 for Service A and $350 for trans fluid change, but they only change half the fluid and I wasn't able to convince them to do it the correct way. Still a ripoff, IMO.
