Rear Sunshade Will Not Deploy
My rear sunshade is stuck in the down position. Pressing the button yields no results, no noise, nothing but silence.
Checked the fuse diagram and it seems that the fuse which controls the sunshade also controls several other vitals which are all functioning so I don't think it's the fuse but should I check despite this (it's in the more annoying fuse box) Anyone know if this is a dead motor, or a switch / issue with the button? I get the feeling it is a costly fix. Searched the forum and Google only found basic information for older w203, w202 models. Anyone who has had their sunshade serviced, or has an idea what my issue may be please help. |
That happened to mine. I just kind of wiggled it a bit as my friend kept hitting the button and then it just started working again
When yours was not working was it dead silent? Mine makes no sounds not sure if it should be though, like as if it were attempting to open.
I'm curious about this too since mine stopped working last fall. I've only tried wiggling it, then going up to push the button. It is silent also, so I'm not sure if the motor is fried or if its just stuck. I have an extended warranty though The Warranty Group, but have been told it probably won't be covered.
Bump any updates guys? I wonder if the stealership will assess the problem for me without charging.
Johnny, what happened with your sunshade?
Hi, I forgot to reply, thank you for asking.
I fixed it! I had a friend press the deploy button and gently tugged on it simultaneously. After a few try it deployed and has consistently been working for over a year now! |
Johnny, watta I noticed that the rear shun shade is connected to the rear Sam and when the sun shade is broken it'd affect other parts like reverse lights, parctronic system, mirrors memory and 3 to 5 things else.
My rear sun shade isn't working now, now I'm wondering who can help me with solve my war with W211. Do you think that the key switch is damaged ? Or another parts are falling apart? Please help! And I posted that but only 1 reply. |
Originally Posted by JohnnyC300
(Post 6517630)
Originally Posted by Hekkie Smith
(Post 6517780)
I'll try it today then ima tell you
It didn't work
Sorry man, I would say go about it at the stealership. I think I asked once and they implied it's expensive. I believe I may have read $1200 on this forum but do not be discouraged and do a search. I bet an indie with an auto electrician can do it for $100.
Johnny thanks for your concerns, My sun shade is stuck up not down
And I'm asking about the sun shade because some stealerships said that it's the main reason of all the malfunctions |
Rear sunshade will not deploy
I tried to deploy my sun shade just morning, and it did not work however after pulling over and cutting down the radio I was able to hear a click when I pressed the button. any clues of what I can do to get it working because I do not hear anything except when I press the button
Originally Posted by craiger13
(Post 6826987)
Hey Check fuses Check the motor Check the rear Sam (Make sure that you don't have any other problems) Does it rain too much in you place ? Try to hit with your bunch it from the trunk Check the car with c4 or c5 star Best wishes I had it before though:slap: |
(Post 6827368)
Hey
Originally Posted by LandSeaAir
(Post 6827379)
It would be the front SAM which may be the issue, but likely not because the other components on the fuse are working.
Sometimes it gets stick by itself just try to hit the motor from the trunk |
https://cimg5.ibsrv.net/gimg/www.mbw...4741a8297.jpeg
(Post 6827426)
The rear Sam controls the rear sunshade
Sometimes it gets stick by itself just try to hit the motor from the trunk https://cimg7.ibsrv.net/gimg/www.mbw...286e91f42.jpeg https://cimg2.ibsrv.net/gimg/www.mbw...9c7bccba9.jpeg |
(Post 6827433)
https://cimg7.ibsrv.net/gimg/www.mbw...286e91f42.jpeg https://cimg2.ibsrv.net/gimg/www.mbw...9c7bccba9.jpeg Look if you hear a click sound when you hit the sunshade button this means the motor is working So you need to check the track of the sunshade That's it Best |
This just happened to me rn. Do I need to keep pressing immediately the button while tugging the sunshade?
Mine stopped working at least 2 years ago. No noise. I'll have to try to pull method.
Well, thanks to the suggestions here, I pulled up (moderately) on the shade while another person pushed the button. It now works consistently!
I would like to add my 2¢. My new to me 2007 CL600 had a non-functioning rear sunshade (note "had"). I heard a very quiet "click" when I hit the FAVORITE button, so I figured it wanted to work. I had my wife hit the FAVORITE button while I pulled on the middle of the shade. After a couple of tries, EUREKA! Getting a purchase point was a little tough, though. I pushed on the plastic above the shade just enough to get a finger-hold, and that was just enough of a bite to get the job done.
Thanks to everyone who puts these random hints and tidbits on these forums! John |
Originally Posted by aamirani
(Post 5931875)
