Tire advice for rotating (4) 18X8 rims
Old Mar 13, 2014 | 11:04 PM
yan91481's Avatar
C250
Fellow members:
I'm new to the forum and would like some advice to complement rims that I recently purchased (Falken RT7M - 18X8/40 offset)...see picture below!
My goal is to rotate all 4 tires on a stock 2012 C250 without having it lowered or experience any rubbing. Stock the vehicle has a staggered fitment with factory recommended F225/45/17 on a 7.5 inch rim & R245/40/17 on a 8.5 inch rim.
Can anybody recommend tires that have worked well for them and possibly attach pictures for review.
Thank you in advance for your help!
Attached Thumbnails Tire advice for rotating (4) 18X8 rims-rim.jpg   Tire advice for rotating (4) 18X8 rims-photo-1.jpg
Old Mar 13, 2014 | 11:44 PM
Knightmare69's Avatar
2010 C200 CGI
I'm running 225/40/18 Mich PSS all around, had Nitto Invo's before that. The Nitto's were good but didn't last long for me, the PSS is much better grip and supposedly longer life. But the PSS's are somewhat more aggressive in other areas also, so not sure if you're ok with that.
Old Mar 13, 2014 | 11:56 PM
yan91481's Avatar
C250
Knightmare69 - thanks for your feedback, I was hoping that I would be able to go wider than that...maybe 235/245?? If so, what profile would be recommended? Worst case scenario I will go with your recommendation. Thanks
Old Mar 14, 2014 | 12:36 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
You can run 235s at front but I am not sure if wider than that will be wise as I haven't seen anyone on the forum post wider than 235s at front. Some people run a square 235/40 and that will be perfect for your 8" wide rims as it won't look stretched.
Old Mar 14, 2014 | 01:57 AM
2010 C200 CGI
You should be able to go 235, 245 I'm not sure unless you go 35 profile tire maybe? Just to let you know, I'm running +33 offset in the rear with 225/40/18 lowered on H&R supersport and I don't rub at all, given you're not going to lower your car, you can probably get away with 245 but may have to space your wheels a bit to clear the suspension.
Old Mar 17, 2014 | 12:53 AM
yan91481's Avatar
C250
What are your thoughts??
Here is the finished product (235/40/18) all the way around!
Attached Thumbnails Tire advice for rotating (4) 18X8 rims-pic-2.jpg   Tire advice for rotating (4) 18X8 rims-pic-1.jpg   Tire advice for rotating (4) 18X8 rims-pic-3.jpg
Old Mar 17, 2014 | 01:08 AM
jimbowmanjr's Avatar
2009 C300
Any rubbing? Would love to see a close up of the wheel/fender to see the gap in the wheel well since I am going with a very similar setup in the next week or so.
Old Mar 17, 2014 | 02:06 AM
Nice! get a gloss black AMG style spoiler, paint the mirrors gloss black, paint the roof gloss black and you are done!!
Old Mar 17, 2014 | 09:16 AM
yan91481's Avatar
C250
SO FAR NO RUBBING AT ALL...GREAT RIDE VERY HAPPY WITH THE OUTCOME, WOULD NOT RECOMMEND LOWERING WITH THIS SETUP.
Old Mar 17, 2014 | 09:32 AM
bigigg's Avatar
14' CLS550
That looks good for not being lowered..
Old Mar 18, 2014 | 11:22 AM
2009 C300
Awesome! I think that gap is perfect for me. I was worried about swapping to 18's and needing to lower the car. I want to keep the suspension stock and not have to worry about camber correction and uneven tire wear...especially when the tires are around $200 a pop.
Old Mar 18, 2014 | 11:41 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I'm running 235/40 18s all around and dropped the rear 8mm with a thinner spring pad. My rear seemed a bit more jacked up than other C Class and it looks exactly like Yan's without the spring pad drop. I agree that this setup fills the wheel wells nicely without any worry of dragging anything.
Old Jul 13, 2014 | 11:13 PM
yan91481's Avatar
C250
4 RIMS & TIRES for $995...Lug Pattern 5 x 112
Selling the original rims off my Mercedes Benz C250. (not the black ones!!)
WHEELS: 17-inch twin 5-spoke wheels (7.5x17 front & 8.5x17 rear)
TIRES: 225/45R/17 front & 245/40R/17 rear
The tires that you are viewing have approximately 4000 miles of wear and tear (90% tread left) and the rims show some signs of curb rash. Tire brand is Continental, the ContiProContact series are designed to blend good looks and handling with low noise and a smooth ride.
For more information call or text me at (954) 701-3000. Thank you!
Aftermarket rims...not for sale!
