2010 battery keeps dying
My battery dies overnight or sometimes a few hours. I first noticed it after a car wash a month ago. They had to jump it. Next was about a 2 weeks ago when I was updating the maps it died after 20 min (engine off) and had to jump it. Then yesterday before I left for dinner had to jump it again. Drove about 30 min to the restaurant then 2 hours later had to get it jumped again. This morning the same thing. Would a disconnected trunk light do it? Also my window control lost the 1 touch auto close feature. I don't see how those 2 could drain battery. When I go into engineering menu it has a bunch of low battery warning with voltage going down to about 9-10v
Yup had exact same issues last year. Time to get a brand new battery. after 3-4 years, the battery needs to be changed.
I am now using an Interstate Mega-Tron MTP (recommended) P.S.: don't update maps on battery power alone. Either drive the car during the map updates or get a professional battery charger. |
Originally Posted by RavenMDX
(Post 5976630)
I am now using an Interstate Mega-Tron MTP (recommended) P.S.: don't update maps on battery power alone. Either drive the car during the map updates or get a professional battery charger. I thought our battery is supposed to last 8 years. I'm surprised yours only lasted half that. Mine's almost 6 years old. |
Originally Posted by aznmode
(Post 5976701)
I took it to the dealer and they said the battery doesn't hold charge so it does look like a battery issue. I got charged $252. $165 for the battery and the rest labor after 15% discount. How much did you buy your battery for? I was going to try to do it myself but I don't know of a way to do it without losing the programming on my car. If you swap battery the car needs to be reprogrammed so I figured the dealer would be my best bet.
I thought our battery is supposed to last 8 years. I'm surprised yours only lasted half that. Mine's almost 6 years old. 8 years? hehe not in our benz..too many modules/tech. Your lucky it lasted that long :) |
Isn't there a little 9volt battery device you can plug into the cigarette lighter to keep "voltage" in the car while you are changing out a battery? I've seen that somewhere... not sure if applicable in our vehicles.
Originally Posted by boom132
(Post 5976730)
To do that, key should be turned to the first stop (accessories?). Otherwise the 9V battery is not connected to the main power.
Just a thought.... having the key on accessories may expose your car electrics ie sams to voltage spikes when changing the battery.
If the key is off & withdrawn is there less likely hood of this happening ? |
Battery life
Just another side to this battery issue - 5 years and 2 months on the original OEM battery - and it even held its charge while I left for 5 weeks at home late last year while we were on vacation in Australia!
Used most days and have the auto headlights on 24/7. Just my 2 cents.... |
Original battery on my 2010 as well... I did have to put it on a charger once; overnight. With the freezing below zero Maine winter I've been having, the car has started every morning... pretty impressed with this particular battery so far.
Originally Posted by Carsy
(Post 5978331)
If the key is off & withdrawn is there less likely hood of this happening ? I have a trickle charger and I charge the battery whenever battery reading is 11.4V or below. |
Originally Posted by NewtwoMB
(Post 5978444)
Thanks - I have 59K miles on it now - most of those were done in its first 2 years as I was doing a lot of traveling around the UK and Europe. It'll get another 3000 this year as we're going to the south of France in it in the summer. Great car and looks as good as new (better even as the paint has had a lot of extra care and attention!).
