Putting 19" OEM C63 wheels on my C
Finally getting the wheels I always wanted on my C..
http://optmbr.ru/images/product_imag...ages/134_0.jpg The dimensions are 2x 8J x 19 ET 45 LK. 5x112 2x 9J x 19 ET 54 But I have a question, what tyres can I go for, front/rear? The rubber will be Michelin PSS, I'm thinking will these dimensions fit: front: 235/35/19 rear: 265/30/19 ? Or is 265 too wide, should I go for the default 255/30/19 on the rear? (stock suspension) |
265 you will rub just go with 255/35/19
thx. isnt it 255/30/19 or is it 255/35/19 ? Im looking here http://www.sizemytires.com/make/mercedes-benz/c63-amg
and is the front correct 235/35/19 (just to clarify -> im ordering the tyres so i can receive them at the same time as the wheels) |
my setup i have D2 coilovers installed with 2 finger gaps front and rear. Wheels: 19' Euro C63 Front 235/35/19 and Rear 255/35/19. Full load with 4 passengers no rubbing at all. the size is right and it tucks in perfectly. I am on Bridgestone Potenza's
I have Väth rims in 8,5x19 (offset 45) 235/35/19 and 9,5 (offset 45) 255/30/19 (the best combination for tyres)
Dont Forget to buy MO " mercedes only " if you got [477 TIRE PRESSURE LOSS WARNER]
I got tire pressure loss warner on my car, what should i not forget to buy? Have i missed something?
Originally Posted by Spec_Davis
(Post 6066892)
I have been looking into this setup as well. The vendor recommended going with 235/35/19 and 265/30/19.
I'd prefer to use the 255/35 so i can get the tires that i want (Nitto Motivo).... Does anyone have any thoughts on which size is the best fit for this rim? Below is a link to the ebay posting... http://www.ebay.com/itm/19-Mercedes-C63-C-Class-C250-C300-C350-E-Class-E300-E350-E550-AMG-Wheels-/201103549694?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ed2b4a4fe&vxp=mtr |
I have 255/30/19 all around and it rubs like no other. IMO theres no beating the rub. Its the price you have to pay to look good. Just go slow on turns and minimize the rubbing.
Originally Posted by colt45_
(Post 6071361)
Originally Posted by Karem
(Post 6066899)
Originally Posted by sunessence
(Post 6071428)
Absolutely no rubbing with my set... What's the offset of your rims ?
Look at this. Pretty self explanatory... http://www.discounttire.com/dtcs/infoWheelOffsets.do
Originally Posted by jbickford
(Post 6072597)
(Post 6066626)
http://optmbr.ru/images/product_imag...ages/134_0.jpg The dimensions are 2x 8J x 19 ET 45 LK. 5x112 2x 9J x 19 ET 54 But I have a question, what tyres can I go for, front/rear? The rubber will be Michelin PSS, I'm thinking will these dimensions fit: front: 235/35/19 rear: 265/30/19 ? Or is 265 too wide, should I go for the default 255/30/19 on the rear? (stock suspension) Your dimensions are very similar to my setup (excluding suspension), you should be fine. Those who run 265 on rears and are having issues with rubbing are not running the correct offsets needed for proper fitment. |
Buy tires with MO "Mercedes Only"
3 Attachment(s)
Just to update, i went with the 255/30/19 on the rears and 235/35/19 up front :) Works great and car is amazing.
Attachment 446358 Attachment 446359 Attachment 446360 |
Looking good man. Where did you get the 1 bar grille? I have looked and looked and all the 1 bar grills i have seen have an extra thing 1 bar above the main bar.
Got mine from ebay, just search c63 grill Although I am not living in the us.. Here is one like mine on ebay.de http://www.ebay.de/itm/Grill-Sport-K...item4d1f934f04 |
wheels looks good .. where did you get them from ?
