W204 1997 C280 How do I remove lower right side dash cover/cover/trim?
Old Jul 23, 2014 | 11:45 AM
DriveBy's Avatar
C-280
I need to remove the lower dash cover on the driver's side under the steering column. I've unfastened everything that I can see to unfasten but it's still stuck fast at the upper part to the right of the steering wheel. There's a hole going up through the padded cover at that point so I'm assuming some tool has to be inserted there to remove the panel at that point. I can't locate a screw using a Phillips screw driver.
I have a book that covers several years, but the illustration shows a different panel, so probably a different year.
Old Jul 23, 2014 | 04:40 PM
DriveBy's Avatar
C-280
I finally discovered that it was held by an 8mm bolt that was easily removed once I found the correct socket.
Old Jul 23, 2014 | 05:01 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Why are you taking that apart?
Old Jul 23, 2014 | 09:34 PM
DriveBy's Avatar
C-280
I replaced the evaporator temperature sensor.
