Is that an E Class?
What I plan on doing to get there are
1) remove the C250 badge from the trunk. I have a heat gun so that shouldn't be too hard, just need to be patient and not burn anything.
2) fit some E Class wheels. Most likely 17x7.5 all the way around so I can actually rotate tires and give the missus the slightly less jarring ride that comes with an extra inch of sidewall. Yes, I know it's slightly, but even if it isn't "enough" for her, I still get credit for trying
My current wheels are the OEM AMG 7 spokes which are
Front 18x7.5 w/47mm offset
Rear 18x8.5 w/54mm offset
So I found more than a few sets of 17x7.5 wheels with a 35mm offset.
I think I need to get offset spacers to make up for the difference in offsets. That's either spot on or grossly incorrect. So which is it? (File under the things I never learned because I opted to do motorcycle road racing instead of anything auto related :P )
As far as using E class wheels, I'm pretty sure you can do it with correct size tires and using stock height.
I am going to get a set of 17" if for no other reason than to prove to the missus that I've made an effort to give her a smoother ride. Since that IS going happen might as well put some non-C looking wheels. FWIW, there are some really UGLY MB OEM wheels out there.
So is more of a "make people who think they know what model it is doubt themselves" than making it look like an different model. Someone that knows MB's isn't going to be fooled.
#1 Lower tire pressure (to match manufacturer settings not above).
#2 Swap tire compound to a more comfortable ride.
#3 Swap tires to a larger size for more air volume (example 225/40-18 to 235/40-18)
As far as fooling other's part regarding C vs E. Why not simply swap out the lettering in the back trunk since you already have the heat gun out. Then maybe people will also think you have a diesel (especially when they see the bluetec/blueefficiency logos on the side). Prepare to get flak for this however :P
The objective of smoothing out the ride is to get her to quit complaining about it. When we go on long drives, I'm the one driving and I sure as hell am not going to drive her appliance when there is a Benz in the garage.
I have ZERO interest in the look of the luxury model. If I get a W205, it will still be another Sport, but I'll add airmatic to it if for no other reason than to get her to shut up.
Next Question or would you like to drive the Camry?
Sport model has a terrible ride. They just do. Unless you like a stiff suspension, then it's perfect. It would be easier to mod the grill and fender flares than going about this odd request with switching around tires that will not yield that different of a result since the suspension on your vehicle will still be "Sporty".
Oh and buying 17" rims & tires is actually cheaper than just buying new 18" rubber. At least I can tell her I tried.
I am on the same boat as you. Wife refuses to ride or drive our E90 and C250 because she thinks they both aggravates her bad back. I ended up getting her a 2015 Accord a couple of weeks ago and she's lovin' the ride comfort it offers. I'm kinda...really!
Btw, our C250 came with 18" AMG staggered wheel package if that matters.
As far as softening the suspension, fit luxury springs and shocks - someone will probably gladly swap you. If you were in Australia I certainly would.
As far as fooling people into thinking you have an E-Class, or even hesitating for a moment, who in the world knows enough about mercs that they would recognise E-Class rims but not enough to tell an E from a C?
I'm a Benz tech and I couldn't tell you what rims are from what car half the time.
Just say it how it is man. The missus wants you to do a thing and you are gunna do it. No point trying to hide that from us, we are randoms on the internet. Just own it bro.
