What tyres should i get
Old Jan 13, 2015 | 02:01 PM
ckapii's Avatar
Mercedes (w204)
What tires should i get
I'v got a c220 (w204) with 225/40 front and 255/35 r18 rear. I'm planing to get 19 " wheels (8,5") but not sure on what tires i should go with. I'm thinking to go with 235/35 front but i have no idea what to get for the rear. I don't want to go under 255 in the rear but not much over either. So if u guys could give me some tips that would be great
Old Jan 13, 2015 | 02:48 PM
Skyline45's Avatar
2016 GLE450 AMG Coupe
Forgive my ignorance as it's probably just a spelling for a different language, but what is "tyres"?
However, I'm not sure how to answer your question. I normally just get what ever Michelin the tire place has, and that will fit on my wheel. All four matching of course, because AWD... lol
Old Jan 13, 2015 | 03:11 PM
ckapii's Avatar
Mercedes (w204)
Haha it's autocorrecting what i mean is TIRES
Old Jan 13, 2015 | 05:10 PM
Skyline45's Avatar
Ah, that makes sense. Damn auto correct. Gets me everytime lol
Old Jan 13, 2015 | 07:43 PM
Becksan's Avatar
2018 E43
I'm running 19x8.5" (235/35) & 19x9.5" (265/30) on mine. Tires are Hankook Ventus Evo 2. I'm lowered on H&R Super Sports. It'll depend on the offset of the wheels you are looking at if they'll rub or not.
Old Jan 14, 2015 | 07:25 AM
xjmoe83's Avatar
2013 C300 4matic Sport
Quite a few people spell it that way outside of the U.S. Even the U.K. Continental Website.
Old Jan 30, 2015 | 08:55 PM
ckapii's Avatar
Mercedes (w204)
Well my car is not lowered the only thing is that it has the AMG-packade. what offset should i go with do you think, 35 or 45
Old Feb 3, 2015 | 05:08 PM
diodia's Avatar
2008 C300 4MATIC
I have Continental ExtremeContact DWSs on mine. 235/35, 19" rims, not lowered.
Drives really well on them, good in slush, and snow. Handles wet highways and dry roads with ease.
To get to your question - I went 235/35 all around - looks really nice, IMHO.
See the pic.
Old Apr 13, 2015 | 08:53 AM
irfan_qayyum's Avatar
2007 Mercedes E-350 4-Matic
Advice on tires for 2007 E-350 4-Matic 245/40/R18 vs. 245/45/R18
I need suggestion on tires which I will be replacing on 2007 E-350 4-Matic which currently has Continental ContiPro 245/40/R18
I am thinking of going with 245/45/R18 Michelin X-Ice. This tire is a little taller 40 vs. 45 and I want to raise my car a little bit. Also I am getting a very good deal on these brand new tires which has excellent reviews on snow/ice.
Any suggestion or concerns if I go with 245/45/R18 ; 100 H instead of OEM ?
People talk about strain on 4-Matic transmission and odometer not being accurate if your replacement is not the OEM specifications. Are these things true ?
Old Apr 13, 2015 | 01:34 PM
jpbenz's Avatar
2012 300c, Lancia Zagato
I have heard this about 4matics also. A friend runs 17" non staggered set up on his and has no issues. Can anyone clarify this?
Old Apr 13, 2015 | 02:17 PM
Antique-Ace's Avatar
2014 CLS550-4M, 2013 C350-4M Coupe
Going to a larger or smaller diameter tire than OE will give you speedometer (and odometer) errors. To see the effect changing your tire size would have on your speedometer reading, check here: http://tire-size-conversion.com/spee...r-calibration/
If you have full-time AWD it is usually okay to run a staggered set-up as long as the tires all have the same (or very nearly the same) rotational speed (revolutions per mile). The OE tires on my '13 C350 4-Matic coupe are 225/40-18 fronts (804.6 revs per mile) and 255/35-18 rears (807.1 revs per mile) and are not a problem for the 4-Matic system.
Some full-time AWD system are less tolerant of differences in rotational speeds than others. IIRC the ATTESA system in my '10 G37x started to have problems if there was just more than about 3% difference in the rotational speeds between the front and rear tires. I don't know what the threshold for rotational speed variance is for the 4-Matic system before its starts to become a problem for it.
Last edited by Antique-Ace; Apr 13, 2015 at 02:33 PM. Reason: Added more information
Old Apr 13, 2015 | 02:49 PM
E-350 4-Matic tires 245/45/R18
I want to make clarification to my previous post.
I am not going for a staggering setup, instead I am replacing all 4 tires in same size but instead of going with 245/40/R18 , I want to go with 245/45/R18
So I am only selecting a tire with higher "Section Height" of 45 instead of 40.
Otherwise all 4 wheels will have same tire size.
My questions:
a) Is it OK to put a tire with slightly higher "Section Height" ?
b) How much longer (in diameter) will be 245/45/R18 vs. 245/40/R18?
c) Any disadvantages or strain on 4-Matic transmission ?
Old Apr 13, 2015 | 02:59 PM
My questions:
a) The larger 245/45R18 tire will fill out the wheelwell by an extra 12mm which should be acceptable and not cause rubbing in most circumstances.
When speedometer reads 60 mph the actual speed will be 62.2 mph (3.7% faster) with the larger tires.
b) 245/40/R18 is 653 mm (25.7") in diameter
245/45/R18 is 677 mm (26.7") in diameter
c) There should be no significant added strain on 4-Matic transmission with the larger tires.
Old Apr 13, 2015 | 04:05 PM
Does this also means that my odometer will show more (>3.7%) than actual mileage I will drive ?
Also does it effect the working of TPMS system?
Don't want to run into an issue with TPMS system.
Old Apr 13, 2015 | 04:15 PM
I believe the odometer will show 3.7% less miles than you actually drove.
Old Apr 13, 2015 | 04:18 PM
Any effect on TPMS (Tire Pressure Monitoring System) ?
Old Apr 13, 2015 | 05:16 PM
No effect on the TPMS with the larger tires.
Old Apr 13, 2015 | 07:17 PM
Thanks for all the feedback.
Just got 4 brand new Michelin X-Ice 245/45/R18 , 100H which I will getting mounted tomorrow.
Will share the pictures afterwards.
Old Apr 13, 2015 | 10:09 PM
jpbenz's Avatar
so if your 4matic came with a staggered set up, it is okay to use a non staggered set up without affecting anything?
Old Apr 14, 2015 | 10:28 AM
That's correct. Most AWD cars have a non-staggered set-up from the factory (including my '10 G37x, '10 S5, '11 550ix and '12 Murano SUV).
A non-staggered set up on a 4-Matic won't be a problem either.
Old Apr 15, 2015 | 11:52 PM
Thumbs up Got the new tires installed today 245/45/R18 100H
Finally got new Michelin X-ICE 245/45/R18 100H installed today. Really liked the drive and handling
Initially ran into an issue with "Brake Wear" message in the display, but fortunately it was just a bad sensor connection and swapping the sensor with a new one resolved the issue.
Pictures attached.
Attached Thumbnails What tyres should i get-img_0004.jpg   What tyres should i get-img_0009.jpg   What tyres should i get-img_0006.jpg   What tyres should i get-img_0001.jpg
Old Apr 16, 2015 | 10:34 AM
I'm glad you like you new tires, but I'm curious as to why you put on a new set of winter/snow tires in April in Maryland?
Old Apr 16, 2015 | 11:55 AM
I don't drive a whole lot and planning on using the same tires all year around.
Are there any advantages/negatives if I use the same tire in summer as well ?
I won't be driving more than couple of hundred miles during summer months.
Old Apr 16, 2015 | 12:26 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
The main disadvantage is that they wear very quickly in dry heat. A few hundred miles won't ruin them but you will be cutting their lives short.
Old Apr 16, 2015 | 12:34 PM
I understand.
I don't think driving a few hundred miles during summer months on winter/snow tires is going to be an issue. The rubber compounds in winter/snow tires are optimized for low temperatures, but I don't think the high road temps in summer months are going to damage them with just limited use.
Maybe someone else here with more tire knowledge than me will have a different opinion.
