Need winter tires.. will these fit
Probably a very noob question.
Short story the south got hit with tons of ice etc yesterday and i got stuck in my short commute home from work. I dont really have the option of calling out so i need to get there.
We very rarely need snow tires here so if i could i would rather not buy a whole set if can be avoided.
i have an old set of snow tires from my old TL type S on steel wheels which are
205/60R-16 on 16x6.5 wheels. Would these fit on my 2009 c350?
The wheels are going to be the wrong bolt pattern. 215/55 r 16 is the recommended size for 16" wheels. The tires would probably work as the diameter is really really close. You just need to get new wheels. (Its a tight fit with 16" so be careful). I'd double check the rim width vs the tires you get to make sure you're not stretching them too much.
The tires will fit. Contact Vassilli at powerwheelspro. He has a set of 16" wheels that will fit our cars. From what my research, the 16" will clear the fronts on US version C350s but not the Canadian models.
