Water Damage
Thank you for your help.
I cannot help with the seat removal except that you should take a look for hold down bolts on the seat rack. Also be very careful disconnecting the airbag etc electrical connections . Make sure the battery is disconnected.
As an alternative method which I have employed on previous cars is to sponge out as much excess from the carpet & insulation then lift it in all directions as much as possible by placing convenient objects between it & the floor . Then put a small electric heater fan which has a safety thermostat switch under the carpet in different positions for a few days, leaving the door open & preferably the car in the sun during the day.
Good luck.
