Crack on fog lamp
Old Jul 5, 2015 | 08:12 PM
babyboxer1's Avatar
2013 c350 Coupe
Crack on fog lamp
I was washing my 2008 C350 today when I noticed a crack around my passenger side fog lamp. The crack looks like a circle and you don't feel a thing when you pass your hand on it from the outside.
I have the Hella fog lamp, and I'm wondering, am I able to order just the outer glass, or do I have to buy the entire fog lamp?
Old Jul 5, 2015 | 09:46 PM
FknBoss's Avatar
W204 C300 4Matic - R170 SLK230 Kompressor
I have the exact same thing. Must be common. Keystone has the fog lamps for about 40 bucks.
Old Jul 5, 2015 | 09:50 PM
babyboxer1's Avatar
2013 c350 Coupe
Thanks for your reply - I apologize, I'm not familiar with Keystone (I'm in Canada). Do you mind sending me a little more info on them, and is that OEM at that price? Otherwise, I was just looking through ebay and it looks like it's ~$120 USD from the dealer.
Old Jul 5, 2015 | 11:00 PM
GUTTER-BOY's Avatar
2008 Mercedes C350 W204
I had the same problem. Both lenses ended up cracking and I had to replace them. They were expensive and a pain to replace. Colorado doesn't use salt, but the gravel/sand mixture they use on the roads in the winter wrecks lights and windshields.
I ended up using Lamin-X ( http://www.lamin-x.com/Mercedes-C-Cl...rs-p/mb426.htm ) to help protect the new ones, and they have lasted more than 3 years without cracking (I used the yellow tint). You might be able to put the Lamin-X on now to extend the life before they really crack and you need to fully replace the lights.
The only issue that I've had is the L-X started to really heat up when I had my driving lights on for a few hours when it was dry out (no rain or snow). When it's wet, the moisture helps prevent heat build up.
Old Jul 6, 2015 | 05:27 PM
babyboxer1's Avatar
2013 c350 Coupe
Thanks for your replies - so I'll be looking to order a new lamp and a Lamin-x kit then!
Old Jul 7, 2015 | 02:47 PM
Shimee's Avatar
2010 C350 Sport
Here, I'll save you a bunch of money: http://www.rmeuropean.com/Part-Numbe..._1BC6D23B.aspx
204-820-2256 is the front right
204-820-2156 is the front left
Old Jul 7, 2015 | 04:16 PM
babyboxer1's Avatar
2013 c350 Coupe
Thank you so much, Shimee! Are they OEM at this price? I was OK with $120 at the dealer, but this is a great price!
Old Jul 7, 2015 | 04:24 PM
Shimee's Avatar
2010 C350 Sport
They barely qualify for free shipping too.
Yes these are OEM except instead of going through MB markup, they're probably supplied directly by Hella.
I found this site because I was considering getting E55 fog lights. They have the bulb centrally mounted instead of off to the side, so they'd act better as foglights rather than the W204 ones. But I didn't realize the combo cornering/fog lights are angled: https://mbworld.org/forums/w211-amg/...ml#post4788132 so I scrapped the plan.
Old Jul 7, 2015 | 04:29 PM
babyboxer1's Avatar
2013 c350 Coupe
Not free shipping unfortunately - I am in Canada.
$45 shipping for 1, or $46 shipping total if I order right and left. Thinking I'll bite the bullet and just order the driver side too...
Old Jul 7, 2015 | 05:34 PM
FknBoss's Avatar
Yes hella is the oem supplier.
