C220 CDI W204 2008 - EGR valve and cooler - coolant leak
Hi Guys,
On my OM646.811, C220 CDI W204 I occasionally get coolant low level warning almost every 1200 miles. So I top it up with with water approx 150 - 200ml - this is normally enough to submerge the coolant sensor into the liquid and for the on screen message to go away. I do roughly 4000 miles / month.
I think I do know where the leak is since it started happening about 2 months ago. On close inspection I found a smear on EGR valve and cooler unit (photo attached). If I clean this, it comes back after almost 250 miles and stays there like that.
The reason for my post is to find out if this is a known issue with w204s also what can cause this and does this needs investigating further or the gasket replacement is a simple cure or even attempting to tighten the torx screws a bit. Also does this unit only carry coolant and no oil ?
Thanks in advance.
Hi Guys,
I have not experienced it with my 220CDI .
If it were me I would try tightening the screws a little keeping in mind the threads are alloy. Therefore not too much. See attached torque values
Thanks in advance.
1.5 hrs it took me.
Thank you all for your support. Thanks @carsy
