Sticky key? Hard time getting key out. And AC question?
Old Jul 12, 2015 | 01:25 AM
james158485's Avatar
C300
I've noticed my key is hard to remove sometimes. One time I barely got it out after several minutes of trying. I've figured out it seems to be better if I restart the car, put it in drive and then park again. What could it be? 9/10 times it works just fine.
Also, my air conditioner continues to make a lot of noise even after shutting the car off. It only lasts for maybe 20 seconds though. Is that normal?
Old Jul 12, 2015 | 10:03 AM
bawareca's Avatar
'93 SL600, '12 X5 35D
There is a cable between the shifter and the ignition switch that prevents taking out the key when the shifter is not in position "P". Sometimes it develops a free play. Next time this happens try to push the shifter forward and take out the key. If it works you know where your problem is.
Old Jul 12, 2015 | 11:38 PM
C300
Okay I'll give that a try. If that's the case how do I fix it? Will it get worse if I don't do anything about it?
Old Jul 13, 2015 | 09:10 AM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
I believe the A/C noise is normal. I noticed it in mine as well its almost like its still going then vents are closing or something and only lasts about 20 seconds. also the A/C make a bubbling noise if you listen quietly but a lot of people have noticed this as well.
Old Jul 13, 2015 | 12:33 PM
tekfoc's Avatar
Veteran: Army
18 E63S
the dealer has to do shift cable adjustment.
I had the same problem.
