bulb house melt?plz help me !!
Old Aug 17, 2015 | 08:49 PM
prince.ofpersia's Avatar
w204
My w204 problems !!!
my w204 problems
hello my friends
im mew member here !
im very shamed because my english language is very very weak!!or bad!! im sry!!!
anyway ....
i bought mb c200k w204 2009
first problem
but it doesn't have xenon lights , the headlights are halogen 12v 55 w
before it all of my old cars had hid xenon and i cant driving whitout hid xenon lights because i will driving a long dark street every night !!!
we dont have mercedes benz agency here but one of my friends warned me if i change the halogen bulb whit xenon then my bulb house will be melted !! and he said to me He had already seen similar examples!!!!!
i wanna ask you is it right or not ?!?!?
what can i do ?!?!?
thanks alote
Old Aug 17, 2015 | 09:29 PM
sagar526's Avatar
2010 C350
Get some quality HID kits like from the retrofitsource. You'll have proper power output and won't risk burning the projector housing or any of the electrical wiring. Their kits are a bit more than other sellers on ebay but TRS has great customer service along with their warranty and they will walk you through the purchase. I've bought many ballasts and HID kits from them for previous work and retrofits.
Old Aug 17, 2015 | 09:33 PM
w204
tnx
but i want xenon for headlight and i afraid of it the xenon bulb will be very heater that halogen bulb and melt housing bulb lenz or other part of it
Old Aug 17, 2015 | 09:36 PM
sagar526's Avatar
2010 C350
Yeah the xenon and HID kit are the same. As long as you get the 35W kit then you will be okay. If you get a 55W kit then you will produce more heat than the regular halogen bulb and risk ruining your headlights.
Old Aug 17, 2015 | 09:45 PM
Knightmare69's Avatar
2010 C200 CGI
Hi wattage Halogen bulbs do risk melting your housing but that also depends on the brand. Piaa, Osram, Phillips, the brand name bulb companies for the most part will not melt your housing. However if you want HID's then like Sagar526 mentioned, get a set of quality pnp HID kit from The Retrofit Source or AZNOptics, they both sell Morimoto brand HID's which are very good quality, I've been using them for many different cars and have them installed in my lowbeams and fogs now. As you have a 2009 model you should have the halogen projector headlights which will help reduce the glare from the HID lights, but you will still need to aim the lights after the HID install.
Old Aug 17, 2015 | 09:53 PM
sagar526's Avatar
2010 C350
Also note that 4000k-5500k HIDs bulbs will be ideal for maximum light output. Anything above 6000k will have more blue to the light color and decrease the amount of lumens and you will have less visibility.
Old Aug 17, 2015 | 09:59 PM
w204
no i dont want wattage halogen
35wat hid xenon kit will be enough for me
i dont want replace in projectors
i need xenon for low beam only
you mean only high quality hid kits should be installed ?!
here i cant find original kits and only china build xenon kits are available here
and i cant acces to ebay or similar sites ...
if only way is originial and high quality hid kits i will transfer to europe for a few days !!!!
and i say an intresting and wretched thing for you !
i bought this car here 110,000 US dollar !!!
Old Aug 17, 2015 | 11:17 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
This is the kit we'd recommend. 35w so won't have melting issues. Morimoto XB35 are high quality kits.
http://www.aznoptics.com/index.php?main_page=product_info&cPath=2_8&product s_id=65
If your country has any sort of blocking and does not permit purchasing, send us a message and we'll find an alternative method of payment that works
Old Aug 17, 2015 | 11:27 PM
w204
yes we are block from all around the world 😂😂😂
i sent you private message
any more comments about melting?
Old Aug 18, 2015 | 12:54 AM
w204
second problem
any other cm?
Old Aug 19, 2015 | 10:58 AM
sagar526's Avatar
2010 C350
Originally Posted by prince.ofpersia
any other cm?
Those morimoto kits are really good. You won't have any issues with the projector housing burning.
Old Aug 19, 2015 | 11:39 PM
w204
no i dont want it for projectors
i want hid xenon for low beam bulb
Old Aug 19, 2015 | 11:42 PM
sagar526's Avatar
2010 C350
The projector is what the bulb goes inside of. So that glass piece you see is the lens and the whole thing is called a projector. You insert your new HID bulb into there and take the old bulb out for your new setup.
Old Aug 19, 2015 | 11:46 PM
w204
oh sry tnx
Old Aug 19, 2015 | 11:50 PM
sagar526's Avatar
2010 C350
No problem, always happy to help with HID or retrofitting headlights haha.
