2008-2010 Safety Recall: Air Bag Control Unit may Corrode and Malfunction
Part # is 2048206685 although the replacement units maybe coming from a different source and hence would carry a different part #.
And here is an image of the unit and its location:
Air Bag Control Unit - Supplemental Restraint System Control Unit
Of course, they don't have to remove all that is removed above to get to it. Instead, they go in from the side of either the driver or the passenger footwell.
Air Bag Control Module - Access through footwell
Which had been announced but parts were not available yet. Yet now it appears dealers are starting to receive replacement modules.
Recall # 15V711
Whereas the 2nd, more recent one you see described blow, involves the Driver' side Front Airbags which were originally made by Takata.
This one is Recall # 16V081
I'll even "kick it up a notch" and offer the Center Console Remove/Install Steps... . If you follow those till the end, then remove the Air Conditioning vents, you'll have full access to the Air Bag Module...
