Rear left and right marker lamp URGENT HELP
Old Nov 29, 2015 | 07:05 AM
sohailkhan123's Avatar
W204 c class 2008 c200 elegance
URGENT HELP Rear left and right marker lamp
Heya mbworld experts i need help got my car after 3 days from paint job painted front and rear bumpers
My car was all fine when i left it at paint shop but when i received it was daylight car was good going back home on way in evening i tuned on light so i got this
REAR LEFT SIDE MARKER LAMP
REAR RIGHT SIDE MARKER LAMP
cheked the both tail lights connectors are perfectly fine and no melting issue rest all lights are working brakes indicators reverse lights
Is it something related to front bumper or rear bumper opening as the paint shop disassembled them for paint
Please help me wat is it how can i fix i changed bulbs frm upside to down but bulbs are fine
Old Nov 29, 2015 | 11:10 AM
bop11's Avatar
350 GLK, C280
Looks like a bad ground from the paint job
Old Nov 30, 2015 | 01:50 AM
What does it mean bad ground by paint job how can i fix it is there ny one who can help me
Old Nov 30, 2015 | 02:29 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Are you sure the rear marker light is on? The rear marker light is the small 194 wedge bulb on the upper edge of the tail light assembly. You should be able to pull out the light bracket from the tail housing and turn on the lights to see if that bulb really is coming on or not.
Old Dec 1, 2015 | 02:14 AM
Heya bro jus checked it properly the small bulb not working i took them out n checked closely both the bulbs r burnt may i knw why thy r burnt they were fine when i left my car at paint shop
Have ordered new one but i have a question this small bulb is a push n pull type so is there ny specific side of the bulb that i have to keep up or down or i can jus plug it by anyway
Old Dec 1, 2015 | 02:57 AM
AZN Optics's Avatar
No idea why they're out. Would have to check with your shop on that. Either way, if you're simply replacing with standard halogen 194/T10/w5w wedge bulbs, just simply plug it in as it'll be polarity independent. If using LED bulbs, then depending on who's LEDs you go with, there might be polarity dependencies.
At least it turned out to be an easy fix with a simple bulb replacement rather than messy and potentially expensive electricals.
Old Dec 1, 2015 | 04:44 AM
Yah man exactly u saved me frm extra expences thanks alot
N i will use the oem lighta not leds
Hers a pic
Old Jan 31, 2016 | 09:48 PM
kodpkd's Avatar
c300, Maserati coupe
I have the same warning for my "right rear side light".. BUT,,, when I went outside, the bulb was not on,,, I tapped the outside of the light, and it turned on. I think there is something that gets loose on these lights.
