My findings with variant coding tweaks and throttle delay
Old Feb 27, 2016 | 12:17 PM
  #76
Merserybenze's Avatar
2022 AMG GT 53, 2020 Sl450. Did drive 2018 S450
This is not for the feint hearted. I'm about to give up and send the kit back.
Vediamo looks like its connected. I see the flashing light on the C4 indicating communication. Attached are screen shots. I can't seem to actually connect to my car and Vediamo seems to indicate I'm in simulation mode. I did install it correctly and got the license too. Any help would be appreciated before I call it a day. Thx
Old Feb 27, 2016 | 03:43 PM
  #77
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
I can't at the moment, but I'll see if I can put something together for you tomorrow morning that should help out. The good news is that Vediamo sees the SDconnect. For whatever reason, you'll always be in "simulation" mode even though it isn't actually simulation mode.
Old Feb 27, 2016 | 05:35 PM
  #78
appreciate it..thank you.
Old Feb 27, 2016 | 07:55 PM
  #79
ghlkal's Avatar
2012 E550 v8-Biturbo
Originally Posted by Funkwagen
Gas mileage hasn't changed from stock settings at all in my experience. I tend to have a heavy foot, and I never noticed much of a change in mileage at all
Originally Posted by xEryx
I am averaging 17MPG for over 1000 miles now, but I do a lot of city driving and still drive it like I stole it 50% of the time.
Thanks guys. I wouldn't expect a major difference -- except if you are constantly getting into the throttle
That's correct. I've tuned my LS series GM V8s and there's a learning curve to be sure.
Old Feb 28, 2016 | 10:25 AM
  #80
Thanks Funkwagen.
I copied over all the database files but now get this error. Do I have the wrong version of the files?
Old Feb 28, 2016 | 11:19 AM
  #81
michail71's Avatar
2013 C250 Sport
Whereabouts in Florida are you located? I'm in Palm Beach county.
Seems people in these car forums are often from Florida, New York, the Middle East or Canada, lol.
Old Feb 28, 2016 | 04:42 PM
  #82
Success! - I think. I removed Vediamo, reinstalled a fresh copy, patched it, copied over the CBF files and relaunched. I am able to make contact with with my ME97 ECU. I can get into variant coding but not sure what to do next. I don't see the screens that Funkwagen shows in the screenshots. Will keep working on it - to think i was so close to sending the kit back
Old Feb 28, 2016 | 11:00 PM
  #83
xEryx's Avatar
2019 E63s AMG
Once you are in the variant coding screen, you just go to implicit coding at the top and you will see all parameters.
Old Feb 29, 2016 | 07:19 PM
  #84
Thanks. Now I see the parameters. I wasn't sure how I change them so i tried the ecu coding and manual coding buttons but it wasn't clear how the parameter is changed. Then i did get a few errors. pls see below. would appreciate further guidance. thx.
Error: Service execution failed. Reason:
CAESAR DiagManager 06067 DiagService refused.
Looked on *******.com but it's not clear how to fix this error.
Attached Thumbnails My findings with variant coding tweaks and throttle delay-img_1482.jpg   My findings with variant coding tweaks and throttle delay-img_1483.jpg   My findings with variant coding tweaks and throttle delay-img_1484.jpg   My findings with variant coding tweaks and throttle delay-img_1486.jpg
Old Feb 29, 2016 | 08:05 PM
  #85
Funkwagen's Avatar
Run these functions (double click em) before doing any variant coding
Old Feb 29, 2016 | 08:10 PM
  #86
but how do i actually select the deactivated parameter setting? do I use the manual coding button or the ecu coding button when I'm in the implicit variant screen? I'm being cautious as i don't want to fry my ECU.
Old Feb 29, 2016 | 08:57 PM
  #87
Funkwagen's Avatar
Either works, I use the ECU coding option. You won't fry anything, technically nothing is being flashed, it's just a code string being changed
Old Mar 1, 2016 | 03:15 PM
  #88
xEryx's Avatar
2019 E63s AMG
FYI - Anyone near PA wants this done, but doesn't want to deal with the hassle of getting a STAR, let me know.
Old Mar 1, 2016 | 03:35 PM
  #89
😀 Boy is it hassle. If I had not already bought the equipment and spent many hours trying to get it to work I would be driving up to PA from Fl about now!
Old Mar 1, 2016 | 05:01 PM
  #90
michail71's Avatar
2013 C250 Sport
I normally enjoy things like this but it sounds tough! It sounds worse than some of the software engineering I have to do, lol. Part of the issue seems to be a lack of a larger online community doing this stuff.
Old Mar 1, 2016 | 05:46 PM
  #91
I did. did not work. see below. I don't know what to do. Any help will be appreciated (a whole bunch of w204 owners are counting on me )
Old Mar 2, 2016 | 02:15 PM
  #92
very rarely do i accept defeat- but this is one of those times! I did buy Vediamo 5.00.06, activated it, patched it, added a large CBF database that I also bought. a whole new set of errors! Anyway, sending the kit back to China! Sorry to those folks who were relying on me to fix their throttle lag. I may try Xentry/DAS with C3 - which i hear works nicely. If I do i will post here.
Old Mar 2, 2016 | 02:35 PM
  #93
xEryx's Avatar
2019 E63s AMG
Nooo, you are at the last step dude! Literally once you figure this errors out, you click those parameters, click deactivate, click ECU coding and done.
It seems all you are missing is turning off the coding security on the ECU since it keeps saying refused.
If what funk said doesn't work, try clicking these CJ/DJ entriegelung
Old Mar 2, 2016 | 04:40 PM
  #94
I did..i got other functions from ******* to try also but those did not work. Believe me, I tried a lot of things including buying an updated version of the software but no luck.
Thanks to everyone who tried to help via these pages and via PMs esp Funkwagen. My kit is on it's way back to the chinese motherland. I'm looking on eBay for DAS/Xentry with C3 and will try that.
Old Mar 2, 2016 | 11:12 PM
  #95
Rodpwnz's Avatar
C300 sport
I'm sure I speak for everyone when I say that there is no need to be sorry at all, and I hope you understand how much we appreciate your time and effort. I can understand your frustration and I'm not even dealing with it directly. Please do not allow any of us who are considering the group share to have any burden or pressure on you to perform.
You are very kind to consider sharing with us, and I cannot speak for others on this but since I am on the other side of the USA, I would not feel right without at least helping a little with the cost of the system.
I'm impressed with efforts of everyone in this thread who has tried to undertake such an endeavor. Good luck Merserybenze.
Old Mar 3, 2016 | 08:14 AM
  #96
Funkwagen's Avatar
Sorry things didn't work out, I received your PM last night but couldn't find any info on that error or why it was occuring for you. I got the same one and activating those two functions completely solved it for me. Strange. Hopefully you'll have better luck with a different kit, sometimes some kits don't communicate well with the cars I've read, that might have been part of the issue, but there's no way of telling..
Old Mar 15, 2016 | 05:30 PM
  #97
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
OKAY!!! I just met up with Funkwagen a couple of hours ago...............MY CAR FEELS LIKE A WILD BEAST OUT OF HELL!! this change is priceless. I don't mean to rub it in but god damn the car feels like it has no lag in corners, straights its honestly a world of difference it feels like a new car. I took the extra long way home down some winding country roads and damn it flys now, in corners, passing people. its not a slug anymore its so consistent. Im still in shock a 10 minute change made me fall in love with the car all over again. (never lost the love but the lag was annoying and awful in corners).
I haven't had a chance to drive in E mode as i quickly put it in sport.
in sport mode its so zippy now so much power and the torque is amazing what a change. it feel like it knocked 2 seconds of the 0-100 time because there was no lag the power is instant and it just keeps going. I love the change and highly recommend if any one lives close to these two guys drive down pay what ever they ask and get this done(of course only if they offer it to others). once you drive the car you feel the difference and it puts a smile on your face. I could not be happier If people would like an update after a few days ill let you all know but I might not be able to respond as fast I feel like going on a spirited long ride lol.
THANKS AGAIN Funkwagen!
Old Mar 16, 2016 | 12:01 AM
  #98
ghlkal's Avatar
Nice!
Old Mar 16, 2016 | 08:26 AM
  #99
Funkwagen's Avatar
Glad you're happy with the results! Yeah, if anyone near me or in the Toronto area is also interested in having this done, feel free to send me a PM
Old Mar 16, 2016 | 10:43 AM
  #100
xEryx's Avatar
2019 E63s AMG
Nice, sounds like we were not giving this change enough credit and almost made you not do it. Well there it is folks, anyone that wants to drive to PA hit me up
