DIY brake bleed + flush
My brakes seemed a little soft (definitely working fine though) and I recently replaced all my pads so I wanted to bleed my lines and flush some new fluid through them. I'm trying to keep costs to a minimum and I have extra time to do this myself so I'm wondering if it's possible/ok to use the traditional old school handheld vacuum pumps to get this done? I'd rather not invest in a power bleeder and don't mind spending an extra hour doing this - will I be ok?
Two more questions:
1) What's the easiest to find/most readily available brake fluid I should use, and
2) Are there 4 nipples only that need to be bled or are there 2 on both front calipers? I was reading multiple accounts so I wasn't sure.
2008 C350
Thanks guys.
Two more questions:
2008 C350
Thanks guys.
2008 C350 Eurocharged
DOT 4 for your car and unless Mercedes is different than every other car on the road, each caliper should have a bleeder bolt.
http://www.pelicanparts.com/techarti...ing_Brakes.htm
I found a lid with the same size & thread as the brake reservoir & fitted an air nozzle to it. I use my home compressor to apply about 20 PSI to the reservoir & bleed each brake caliper in the correct sequence taking care to refill the reservoir often to prevent air ingress. I find 500ml will flush the system. It is useful to find a brake fluid with a different colour which helps to indicate when fresh fluid has arrived at the bleed screw.
. This link may be interesting :-
http://www.vaglinks.com/Docs/Misc/BM...ureBleeder.pdf
I cannot see any problem using your vacuum method except that it could be tedious.
JC
JC
Two more questions:
2008 C350
Thanks guys.
Two more questions:
2008 C350
Thanks guys.
The vacuum at the nipple is the way I did my last 3 brake bleeds and I really like it. Easy, clean, convenient :
<img src="https://farm6.staticflickr.com/5824/23704868845_5eb8cb6ce0_z.jpg" width="640" height="480" alt="image">
The method is universal :
<img src="https://farm1.staticflickr.com/719/23322491400_c39b427053_z.jpg" width="640" height="480" alt="image">
Some like/recommend the LV fluids but I like good ole TYP200 in CA :
<img src="https://farm6.staticflickr.com/5690/23596352442_dc7cd8515c_z.jpg" width="640" height="480" alt="image">
JC
JC
Any idea where I could buy a brake fluid reservoir lid off the shelf, locally? Can't imagine they sell Benz ones at Autozone but maybe one from a different make/model might work?
Originally I was thinking the hand type vacuum pumps but for the price I'm seeing I might as well just buy a pressure bleeder or build my own like the link above.
You don't say where you're from but for stuff like this I just Amazon it, especially if you have Prime.
I think the cheapest way is to jack the car up, remove a wheel, loosen the brake bleeder bolt and let it drain, making sure to keep the brake fluid reservoir filled.
Once you start seeing clear fluid come out of the caliper just tighten it back up. Using this method requires some time, but you essentially just need a wrench to loosen the bolt and something to catch the fluid.
*Do NOT press the pedal if you use this method.
Check a few lids that are the right size to see if the thread is correct.
A car wreckers might be the answer too.
On my older vehicles I have always bled the brake system by a second person pushing the pedal down lightly ie say 1/3 travel & then I nip the bleed valve shut on the pedals return. I have never had a problem.
I have a question. Why cannot this method be used on modern vehicles?
speed bleeders allow one man to pedal bleed the system.
On the W204 I've done that, gravity, motive bleeder and the mityvac vacuum method. The last one is my favorite.
+1 on the MityVac Bleed. Very easy fast and clean. 1 DIY would pay for the cost of getting the mityvac.
It's only been 9 years since the W204 came out. In time I'm sure we'll figure out exactly what prevents it. I for one am curious.
I just build a DIY version of the pressure bleeder, the only thing I need to get is the darn brake fluid reservoir cap and Benz wants $20 for it, lol. There's tons of aftermarket caps at Autozone/Oreileys for other car makes, just no Benz.. Anyone know of an identical make/model that would fit? I've even seen videos online of people using PVC end caps with certain threads and I would do that but I just don't know what size to get. Maybe I should just take the cap down to Home Depot and screw it onto some pipes and find out..
Cost at minimum would be to use the two-person method, the "old school" technique where the second person pumps on the pedal and you open/close the valve. Just keep the reservoir topped off. Very easy, you should already have all the tools (1 wrench? lol). Cost will be the cost of fluid.
