2009 W204 (T Model) Offside boost pipe relacement
Old May 25, 2016 | 08:13 AM
Oldskoolflash's Avatar
c220 S204 2009
Hi,
Has anyone done this, and can advise on how easy a job it is or has anyone come across any videos online? I am being quoted £400 for MB to change it (which sounds extortionate). Also, is it just an air pipe or does it contain oil, the technician said mine is leaking oil...? I would be comfortable changing an air hoe, less so with draining oil systems etc.
Finally, can anyone recommend where I can get a cheap genuine part - I have tried eBay but they only have used parts.
Thanks in advance.
Old May 25, 2016 | 11:46 AM
Knightmare69's Avatar
2010 C200 CGI
Originally Posted by Oldskoolflash
Hi,
Thanks in advance.
You're talking about the throttle body side correct? It's fairly easy but you'll need to jack your car up and remove the tray to access the other side of the pipe.
To remove it, push the pipe towards the throttle body and then pull the metal ring up and then pull the pipe off. Same deal with the intercooler side, push towards the intercooler pull the ring and then pull the pipe off.
Yes, there will be oil in there, I think they all do, I know mine did.
Old May 25, 2016 | 12:08 PM
c220 S204 2009
It's the LH side looking at the front of the car.
Do you have to replace the oil or just drain out what's in there?
Thanks for the help btw
