garmin map pilot in 2010 audio system
hello everybody, and thanks for your support.
I have one w204 c200 2010 year. audio system is the one that come with gps built in.
I want to use the garmin map pilot sd card. the head unit has sd card reader. (see the attached picture)
question is: if I try to use the garmin map pilot in this gps unit, will it work..? any experience...?
Highly doubtful this will work!
Often times, a different version of the same Navteq update software will not install, lock the system up, or otherwise cause other issues... And in your case, you are going to a completely different platform.
I think to do what you want you need to invest a lot of time, money, and knowledge. If you truly want to change GPS look up MegaCrazy's build thread. He truly is megacrazy.
