?DIY Serpentine belt replacement?
Old Aug 22, 2016 | 01:42 PM
horive's Avatar
2012 C250C Sport Coupe; 2008 c-300 4M
Anyone out there have a DIY to replace the serpentine belt on a 2012 C250C? (This is the l4 Turbo changed engine - not the V6. It seems simple enough, but the intake gets in the way if approached from above... Any guidance is truly appreciated.
Old Aug 22, 2016 | 09:43 PM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
You should be able to through a breaker bar or ratchet on the tensioner and move it back a little the belt should come off! If you need the belt configuration I can get you the illustration.
