2009 C300 Command Problems
Old Jan 8, 2017 | 05:09 PM
Kesh's Avatar
2009 C300 4MATIC
Hey guys,
My brother plugged in his iPod to the iPod connector, which he always does, but it seems this time it may have messed up the command system somehow. The command system does not recognize my car is on and shuts itself off after 30 minutes, although I'm driving. The right side of the steering wheel options do not work and the dial pad does not light up. Also, I have to manually shut off the command system, which can get super annoying.
Does anyone have any suggestions on how to troubleshoot this?
I feel like it might be a simple fix so I don't want to take it to a MB dealer just yet.
Old Jan 8, 2017 | 11:57 PM
charles.soori's Avatar
2014 ml63 and 2014 ml350 bluetec
You should be able to go into command engineering menu and check for errors and see what's going on.
Old Jan 9, 2017 | 12:21 AM
Kesh's Avatar
2009 C300 4MATIC
How do I do that?
Old Jan 9, 2017 | 12:26 AM
To access engineering menu hold on to hangup button + #+ 1 on your headunit. Then there should be an option to check for error. Make sure you don't change anything. To exit you can go all the way down and press end.
Old Jan 9, 2017 | 02:41 PM
Kesh's Avatar
2009 C300 4MATIC
I do not see any option to check for error. Is there anywhere specific I should look?
Old Jan 9, 2017 | 02:45 PM
It's under 5.history information then diagnosis record and check both option, historical and chrono stack
Old Jan 9, 2017 | 02:57 PM
Kesh's Avatar
2009 C300 4MATIC
this is what I see, I have no idea what any of this means
Old Jan 9, 2017 | 03:00 PM
IC is instrument cluster
CGW central gateway
EIS ignition switch.
try clearing error and see if it comes back.
Old Jan 9, 2017 | 04:16 PM
Kesh's Avatar
2009 C300 4MATIC
CGW central gateway
After pressing clear only CGW disappeared. IC and EIS are still present. But the problem still continues
Old Jan 9, 2017 | 05:26 PM
Seems like it's not getting the signal from eis that's why it keeps turning off. Are you having anything other problem? Your car starts up fine everytime without problem?
Old Jan 9, 2017 | 06:14 PM
Kesh's Avatar
2009 C300 4MATIC
Thats the only issue I have. Everything else works perfectly fine
Old Jan 9, 2017 | 06:15 PM
Kesh's Avatar
2009 C300 4MATIC
Should I do a factory reset?
Old Jan 10, 2017 | 09:17 PM
Yes try doing a factory reset or system reset go into engineering menu. If problem precise then you might need a full car scan.
Old Jun 21, 2017 | 08:48 PM
drnumie's Avatar
C350, Acura TL type S
@charles.soori I have EXACT SAME problem. I totally understand your frustration. did you ever find any solution to this problem?
any help would be much appreciated.
Old Jun 21, 2017 | 08:51 PM
@drnumie i don't have this problem its kesh that has the command shutting down problem
