Is it possible that install the OEM c63 brake on c250
My car is 2012 W204 C250 coupe 1.8T. I just got a set of OEM w204 c63 brake. Front and rear with everything which MB offered.
I am wondering that is it possible to installing it on my c250
Yes, however you need at least 19 inch wheels for the 6 piston AMG calipers to fit.
This is not entirely true.... certain 18 inch rims WILL clear the front 6 piston calipers. In fact, C63`s came stock with 18 inch rims standard (high offset). Just pick up a set of stock 18 inch AMG wheels from a C63. Worst case scenario, you just have to grind off the tab (ear) of the end of the caliper and then most 18 inchers will clear.
people really need to use the damn search function....
I'll answer you though, NO you need a custom bracket made to get the callipers to stay on/fit. you can use 18's or 19's if you go with AMG rims.
if your going to do this just go with a big break kit that is already made up like brembo's or a few other brands.
its expensive though
