First C300
Old Feb 17, 2017 | 11:46 AM
Jett's Avatar
I drive an '11 C300 and wife drives an '11 GLK350
First C300
I just bought a 2011 C300 with 59K miles on the clock. Loving the car so far but haven't driven it much. I will keep it stock for a bit but have been reading this forum a bit as to modding it a little.
1. Rear diffuser. Would love to get a fitted unit that doesn't need a ton of work to fit right as I am not much of a mechanic or body work person.
2. Window Tint. Living here in Texas it's going to be a must have.
3. Possible exhaust change. I don't need a race car sound but a bit of a more menacing growl would be nice.
4.HID head lights? Not too sure about this but just starting to read up on it.
5. Front grill. Not that I don't like the grill but I did see a cool all black version on here. Might have to look into that as well.
Any other tips would be welcome.
Old Feb 17, 2017 | 12:32 PM
Just204's Avatar
Mercedes w204 4matic sport
I bought my first c300/mercedes almost a year ago, really like the car and has been great with no problems. be sure to do preventive maintenance. though if your not aware. Enjoy the car, I have been . And welcome.
Old Feb 17, 2017 | 01:39 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Welcome! I have had mine about a year as well. Everything is pretty solid. What kind of exhaust sound are you looking for? Youtube has lots of clips, and really you don't need to invest in full exhaust. In terms of the grill, I plasti dipped mine a bit (I have a post as well); w204_generic I believe is selling his old grill, OEM with gloss painted slats.
Old Feb 17, 2017 | 05:55 PM
Demvang's Avatar
2011 C300 4Matic Sport
For the diffuser, carbon fiber or not, I suggest one with big fins, you'll love the look. Also add the quad exhaust tips.
Old Feb 17, 2017 | 07:44 PM
intrdrgn's Avatar
2010 Mercedes C300 Sport
Congrats! I had mine almost a year as well. It's my second c class (1996 C280), Love this class. anyway enjoy yours.
Old Feb 17, 2017 | 09:57 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Congrats and welcome. I have 55K on my C300 without issues.
I agree. If you can't confirm the transmission fluid has been changed (due at 40K), be sure to take care of that. 60K will be plugs along with regular service (oil, etc). Don't skimp on the preventive maintenance. But, then mod away
Old Feb 17, 2017 | 11:31 PM
Jett's Avatar
Yes I have the complete service history of the vehicle and plan to keep up with everything as needed.
I am going to be looking at the carbon fiber or carbon fiber looking rear diffuser first. Changing out the exhaust tips as well.
If someone has a link to a reputable company for the cf diffuser that would be great.
Old Feb 18, 2017 | 04:25 AM
OrientBlau's Avatar
2011 C300 4MATIC
The car looks great! - I also prefer the stock look.
I just got a 2011 C300 4Matic Luxury less than 3 months ago myself. Got a good price, but high mileage (90K on 6 yr old car).
Things I needed were motor mounts, shocks, struts, wipers, and new filters all around.
Old Feb 18, 2017 | 03:44 PM
Shimee's Avatar
2010 C350 Sport
I have 105,000 on my 2010 and the only mechanical issue I have is with the transmission. Occasionally it slams into gear when going from 4 to 3, especially when it's cold. There are other, random gremlins too. No amount of transmission software updates have helped.
There is also a ticking coming from the engine which has been expected. After a while the carbon buildup on the valves needs to be blasted off with walnut shells.
You may also experience the driver's seat bottom starting to tear along the seam of the left bolster. Happens if you're on the bigger or heftier side.
Another thing I wasn't aware of was that car batteries are good for about 5 years. Shortly after getting my car I would start having issues starting it. I'd turn the key and nothing, not even an attempt to crank. Occasionally an error would pop up on the screen saying the ABS/ESP system was malfunctioning and is disabled. After searching around I learned this happens on cars with complicated electrical systems with a dying battery. After replacing it all problems ceased.
Keep up with regular maintenance and it will be a reliable car.
Old Feb 18, 2017 | 05:12 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This should not at all be necessary on the port injected M272. Use of top tier gas should keep the valves clean. The walnut shell blasting is usually needed only on DI motors, and only some of them. I have been on this forum for a long time and have never heard of any Benz engines needing this blasting.
FWIW, a family member's BMW with the N54 did require walnut shell blasting at 40k miles, but that is a DI motor.
Old Feb 18, 2017 | 05:15 PM
Shimee's Avatar
2010 C350 Sport
I've heard the carbon issue causes ticking and figured mine was headed that way too. Guess I have some other problem. Maybe it's not the valves and something else. I haven't been able to listen to another M272 engine to see if it's normal.
Old Feb 18, 2017 | 05:36 PM
LILBENZ230's Avatar
Purge valve perhaps? Almost certainly not carbon related, though.
Old Feb 19, 2017 | 05:16 PM
arkim989's Avatar
C320 sport 2003, c300 4matic sport 2013, 2018 GLE63 AMG
Dont get carbon diffusor lol too expensive and you only see carbon from up close. I got my difussor on ebay pretty cheap, quad tips little expensive but worth it. Dont forget to remove c300 and 4matic emblems after you install quadtips.
For sound put magnaflow xpipe, 90$ on amazon.
Tint is a must!
Old Feb 24, 2017 | 01:19 AM
Jett's Avatar
Smile
Can I just say how much fun this thing is to drive?
I haven't even put 50 miles on it yet but every time I get to drive I end up with a huge smile.
I can't imagine what the newer coupes are like. Maybe I don't want to either.
Old Feb 25, 2017 | 01:42 PM
Demvang's Avatar
Tint is a must!
Right, i could have saved $100 with non carbon fiber, but ultimately i get a nice, shiny look with carbon. I've been wanting an x-pipe for some time, just need when to pull the trigger lol.
