ABS/ESP not active - warnig light
C-Class W204 & E-Class W211
I have an ASB/ESP not active issue on my W204.007 (200CDI)
I started with a constant warning light, and I had ABR fault code: 5132 Right rear RPM sensor, carry out inspection.
I replaced the sensor (easy task) but still the same problem. Then I removed the hub and installed a new ABS ring. Old one was in bad shape, rusty and with a ckrack in it.
Now I get the ABR error: 5134 Right Rear.... Clean multi pole ring.
If I stop the car and start it again, the ABS/ESP light turn it selv off when I startdriving, but after a while i commes back. I also feel the car
Any idea why I have this issue after both sensor and pulse ring have been replaced?
Edit: Part number on inpulsering I got from dealer are: A2303570182
Update
I was reading the wheel speed sensor values when driving, and all 4 are showing correct value, however, rear right where I have the problem are dropping down to 0 and then up to correct speed all the time.
Anyone have an idea that can help me further?
