Malfunctions - Power Steering, ABS, EBD, EPS, Run flat indicator, malfunction at sa
C350 4 Matic
Hi everyone! I have a 2010 C350 4matic and when I took it out this morning I received numerous malfunction alerts. Power Steering, ABS, EBD, EPS, Run flat indicator, malfunction all at same time. Has anyone ever had this problem? If so, what needed to be replaced and approximately how much did it cost? Any information regarding this issue is greatly appreciated. Just joined the forum today and this is my first post!
Mike
Mike
hi there i have a 2011 model c200 same issue i just posted my problem today and just saw your post now im hoping to get some info on this too. i will brong it to a service center and find out and let you know if you have not received any reply.
Gartstu39 (04-24-2017)
I had this issue once. On receipt.
Found codes C219700 stored. Found TIPS CASE GI30.20-P-058547. Performed electrical test of harness from B37 (accelerator pedal). to M.E. found all pins have 0.2 LHMS. Accelerator pedal has internal electrical fault. installed new accelerator pedal.
