Rustproofing - W204 2012
Old May 3, 2017 | 02:02 PM
superangrypenguin's Avatar
A car
Hello!
As per MB Canada, I never applied any aftermarket rustproofing to my car and it has served me well. One of the things I noticed was a flaking of crap from the rubber boots underneath the car. I was told it was normal, and it is a result of the constant movement of those rubber boots and that it was factory rustproofing coming off.
When I asked the dealer if that means I should now invest in aftermarket rustproofing they said 'don't bother'. That seems weird though to me. If it's flaking off, shouldn't I "fix" that problem by applying new rustproofing?
Thoughts? - thanks
Old May 3, 2017 | 04:43 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I think it all comes down to how long you intend to keep the car & how severely the road salting is affecting your undersides.
I would do a thorough inspection then make a decision
In our fare country there would be absolutely no need.
Old May 3, 2017 | 06:47 PM
Just204's Avatar
Mercedes w204 4matic sport
It is normal, MBA sprays a coating underneath. Salt has 0% affect on rubber. If you undercoat clean the surface and use 100% silicone film, that's the best thing
Old May 3, 2017 | 08:02 PM
A car
I can clean it, but silicone just attracts "crap" and causes it to stick though. Isn't that a bad idea?
Old May 3, 2017 | 09:15 PM
Just204's Avatar
From what I heard 100% silicone doesn't do that. Has to be pure.
Old May 3, 2017 | 09:18 PM
A car
Oh cool! Learn something new every day, thank you!
You wouldn't happen to know (off the top of your head), where I can buy this right? I've never seen this at Crappy Tire, as an example.
I'd love to breathe new life into the various rubbers on the car (and in the engine bay) but I've long stayed away from it b/c of what I mentioned before. Thanks!
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
waste of money don't do it. check out the Canada regional forms someone answered this question recently
Old May 4, 2017 | 07:05 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
If someone reads this and decides to do rust proofing anyway, NEVER let any place drill holes in your doors or frame to spray the insides with rust inhibitor. I worked at krown for a time, and while Krown as a product is excellent, I wanted to cry every time I witnessed a nice car have holes drilled in it.
(Krown and I'm sure other places will gladly perform the service without drilling holes, you just need to request it.)
Old May 4, 2017 | 04:55 PM
Just204's Avatar
Drilling holes to do that is a horrible idea! Gurranty it will eventually rust. I heard PDR guys sometimes do that and I'd say over my dead body your doing that!
Old May 4, 2017 | 09:36 PM
A car
Same. When I have had rustproofing done they have never drilled holes.
I will drill a new hole in their human body if they tried doing that to my car.
Old May 5, 2017 | 12:15 AM
Carsy's Avatar
I have a 37 year old car that was rust proofed when brand new. They drilled multiple holes holes in each door , subframe, door posts, sills etc. There is not a hint of rust anywhere.They are all neatly covered with durable plugs.
Over the years I have repeated the applications of rust proofing & made sure each door & sill drain is draining freely.
If I had the choice of rust prevention or not drilling holes in days gone by , I would take the former.
The body build of modern cars has greatly improved over the years so extra rustproofing is not required in reasonable climates.
To each his own.
Old May 5, 2017 | 09:08 AM
Funkwagen's Avatar
To each his own.
You've been lucky, the place you had it done probably applied some lithium grease to the drill holes before plugging them, which prevents rust from forming around the holes.
I've seen some work done from other rust control shops where they've plugged the holes without applying any grease, and there's usually an ugly, rusty surprise when you remove the plug.. other times, a plug can fall out, and then the frame/door starts filling with moisture which can be even worse.
My advice to anyone is if you're going to take your car to one of these places, don't do it during "busy" season, as the spray techs will be able to take more time on your car. When you're doing 80-100 vehicles per day, sometimes there isn't enough time to carefully go over everything...
Old May 5, 2017 | 04:30 PM
Carsy's Avatar
Good advice. Wonder what the angry penguin decides?
Old May 5, 2017 | 05:55 PM
Alfadude's Avatar
2012 C300 4Matic
"When you're doing 80-100 vehicles per day, sometimes there isn't enough time to carefully go over everything..."
80 to 100 vehicles done in a day at a rustproofing shop?.....In this day and age? I didn't think anyone even did that to their cars anymore like years ago. Are places like Z-Bart and Rusty Jones even still around? I would think a shop might do 1 or 2 a day. I don't think I even have heard about doing that to their car in years, and I live in a snowy salty area of the country. Factory rustproofing and newer materials and processed used to make cars are so much better than the 70s-80s.
Old May 5, 2017 | 08:58 PM
A car
I think I'll keep on monitoring the bottom of the vehicle. I looked today and there doesn't appear to be much rust in any places that aren't related to the exhaust system (and you can't rust proof that either b/c of the heat).
I'll wait and see, but I don't think I"ll be adding any aftermarket rustproofing.
The ones I have done in the past do not require drilling. IF I do any aftermarket stuff, I'm going back there (in Waterloo) to get it done.
Old May 13, 2017 | 12:47 AM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
PLEASE DONT RUSTPROOF
Did it with Krown with my W164 and they drilled 18 holes into the car. Nightmare. Ended up selling the car.
