Brake Flush w/ Motive Power Bleeder what PSI?
If you do not know what the Motive Power Bleeder is you probably cant answer my question but here is the webpage: https://www.motiveproducts.com/colle...c-bleeder-kits
Anyhow, I want to do my wifes C250. In reading a couple of how to's there seems to be a bit of a conflict. Some say to pressurize the bleeder to the the standard 15 PSI and in some they say to pressurize the bleeder to 2 to 2.5 bar which is around 29 to 36 PSI.
Anyone ever used a pressure bleeder what did you pressurize the bleeder to and why?
Thanks for your time!
I pressure bleed my brake system every 2 years (4th time coming up)& use my small compressor . I find 20psi sends the fluid out of the bleed screws fast enough. Higher pressures are not required IMHO.
