Diagnosing Door Linkage and Actuator Problem
SPONSOR
Do you hear anything in the door making noise when you attempt to unlock it? Agree, pull off the panel and inspect. Listen for any type of noise. This will help with the door panel removal: http://www.pelicanparts.com/techarti...el_Removal.htm
Can also use the article below to inspect the door control unit and you can post a question at the bottom of the article for additional tech help.
http://www.pelicanparts.com/techarti...eplacement.htm
