Transmittion Fault
Old Jul 15, 2017 | 07:27 PM
mh_hawwach's Avatar
C350 2008 W204
Transmittion Fault
helllo , i have an C350 w204 2008 , i am having a problem that when the car reachs between 2000/ 3000 RPM , the rpm doesnt stand still it either decrease or increase even if i am on cruise control same problem happens and when that happens i feel like a slit kick back in the car like it is confused wether to change gear or stay in the same gear, but when i increase the paddle , nothing happens and the car works smoothly and change gear as it is supposed to do , anyhelp will be much appreciated.
Old Jan 4, 2018 | 09:59 AM
gabyuuu's Avatar
C220 W204
Hi,
Something like this ? (noticeable starting 1:41 )
Mine does this only at the first start of each day when is a bit colder outside for about 2 kilometers.
I noticed that if I let it at idle for about 10-15 minutes, before moving it, will work just fine .
Can you tell me if you found out somthing about this?
