Car crank but can't start
Hi All,
My car crank but can't start, the same thing happened to me about two years ago so that time, I just disconnected the battery to reset the power and then connected the battery again then my car started.
Today, I have the same issue the car crank but can't start I did the same thing that I did before but didn't work for me.
I think that the fuel is not coming to the motor, so I want to check the power circuit including relays and fuses of the fuel system.
Any recommendations? where can I find the related component of fuel pump system? or any other suggestions?
Hi All,
http://www.mercedesmedic.com/c-class...ayout-diagram/
If it not help then - I had the same issue, the problem was with gasoline contamination with diesel fuel on the gas station. I had to tow the car to the dealership and flush the lines and new crank shaft sensor.
Or check the plugs, maybe they are dirty, but I don't think that all 6 of them. If you had only one dirty you would still start the car and get Check Engine light as it would work only on 4 cylinders. Only if it not the 1st spark-plug.
Cylinder info:
https://cimg3.ibsrv.net/gimg/www.mbw...0dc6f0f102.jpg
firing Order: 1-4-3-6-2-5
amjad2013 (08-21-2017)
Hi angrybober, thank you for your feedback.
I checked the voltage on the fuel pump which was 12 Vdc while car key on position 4.
So the electrical circuit was ok, then I called the technician to check the pump operation and he replaced it due to malfunction operation.
By the way, I replaced the pump with fuel pump called VDO its a Germany made (Siemens sister company)
