C220 om651 issue
C220 om651 issue
Hi All new to the forum,
Had my c220 for around a month and having a few issues
1. Being what I think is the chain rattle on startup, and after being sat for a hour after a long run is worst had a new tensioner and that seems to have quietened down, but I have a fault for inlet camshaft
I have a engine management code p200a75 The charge movement flap (cylinder bank 1) has a malfunction. The emergency position was not reached
Swirl flaps? But for some reason I’m not getting any where near as good mpg as it did at first,
Also when running and I press and hold the brake for brake hold I get a loud rattling noise? Is this normal?
2011 Mercedes C220 Sport SW
Hello. Found this thread using search, so will not create another, because problem is same.
P200A75The charge movement flap (cylinder bank 1) has a malfunction. The emergency position was not reached
Did anybody fixed this fault ? This is swirls flaps fault that is on the intake manifold ?
