MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   C-Class (W204) (https://mbworld.org/forums/c-class-w204-83/)
-   -   One-touch on right window doesn't work (https://mbworld.org/forums/c-class-w204/688486-one-touch-right-window-doesnt-work.html)
dol4er Nov 10, 2017 02:20 AM
My side windows can be opened with one-touch but cannot be closed. I tried some things that I saw on Youtube but they didn't work...
Any ideas how to fix this?
Rodpwnz Nov 15, 2017 09:45 PM
Could you give us more details? Does the window move at all with one touch? Does it go half way? Go all the way but open a crack left? Do you have any tint installed?
I have tint and both my left side windows, driver and passenger, wouldn't one touch anymore and if I tried to close the window, it would always back up a little bit leave a small space open. If I fiddled with it enough, it eventually didn't roll back down. I would have to do this every time I wanted to roll the windows up.
I took it to my mechanic and they re calibrated the window sensors to accommodate for the tint.
Colin G Nov 16, 2017 04:31 PM
Mine did that too but I have no tint. I did a reset on the switches and it worked fine. Similar to a sunroof reset but I did the same thing with the windows and it worked fine. Maybe I was just lucky? Either way, it drove me nuts since it started doing it one day out of the blue and now it does not so I am happy.
dol4er Nov 17, 2017 02:28 AM
It was a desync problem and it was easily fixed. I found a solution on Youtube. You hold the button for 10 seconds when the window is closed and the problem is fixed.
© 2026 MH Sub I, LLC dba Internet Brands
