How much would saving 60 pounds of wheel weight make a difference?
I'm looking to get lightweight wheels for my 2013 C300 Sport, I was told that saving weight with wheels and tires is a lot more effective then losing weight on the frame, I'm not exactly sure if this is true but I think it makes some sense. Anyway I found out the stock 17" wheels are 31 lbs. each in the front and 33lbs each in the rear without tires. I found wheels that are 17lbs each all around, so that would total 60 pounds in weight savings. Do you guys think this would make an actual performance difference?
Pilfered this off a Porsche forum:
Olaf Manthey explains in an interview : “Removing 33 pounds of unsprung weight at the wheels is equivalent to losing 198 pounds from the body of the car, as a 1:6 factor has to be applied when the car is moving and that weight becomes mass. In fact, we are conservative with the 1:6 ratio, as Porsche considers it to be 1:7.
In my opinion you would notice no difference. Possibly thousandths of a second in a 0-60 run.
