need advice on type of brake pads
Thanks. I already purchased from MB dealership the brake pads and rotors.
BTW , these so called original pads are actually manufactured by TRW (their logo can be found on each brake pad)
Now after the install I’m trying to find the replacement decals that attaches on calipers. Ironically this decals are also manufactured by TRW.
https://www.ebay.ca/itm/TRW-Front-Lo...eRlboQ&vxp=mtr
^these seem to be an exact match with the material as well, still more expensive then the genuine, now that's rare for a mercedes part to be cheaper
Ceramic is not as hard as semi-metallic pads. So no, you don't need special rotors for ceramic pads. However, you do need a clean pair of underwear if you're needing to slam on the brakes when it's cold and/or very very wet out.
xsever (03-15-2018)
#34
It is mostly accepted and hardly contested that ceramic pads don't work well when it's really really cold out. Some people may disagree with my statement that ceramic pads don't work well when it's pouring rain and you're brake pads/rotors are soaked in water. I certainly noticed it, despite our cars having the "wipe" feature that allegedly keeps rotors/pads free of water. That said, even when it's pouring heavily, the OEM pads/rotors have about a 1 second "bite" delay if you slam on the brakes. With the ceramic pads I felt that was delayed quite a bit longer.
If braking performance is key, stick to OEM/semi metallic stuff. If ease of cleaning wheels is key, stick to ceramic. I will never EVER trade my safety again for cleaner wheels, but that's my choice.
#36
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350, 2003 E320
superangrypenguin supports my earlier reply with stronger wording. I have to agree with him 100%. The 2 rather bad experiences I refer to in that earlier reply are:
1-Making a hood ornament out of a Ford F-250 with an ML350; and,
2-Making a hood ornament out of a Lexus LS460 with an E320.
Both experiences were had by alternate drivers who had less experience than I do and who expected the quick response of the OEM pads.
Please opt for braking performance over appearance and convenience.
superangrypenguin (03-16-2018)
#37
So I'm going to play devil's advocate here.
It comes down to the ceramics being able to stay much cooler then semi metallic pads. If you are an aggressive driver and you use the brakes hard, you will get the semi metal pads hot real quick resulting in reduced braking ability. I've experienced over heating semi metallic pads and you do lose a lot of braking ability when going fast. Once i switched to ceramics, the brakes performed far longer with consistent results, that is why race cars use ceramic pads.
Back to running ceramics in winter, yes they stay cooler so they attract more water/ice/snow but honestly if you're cruising on the highway and haven't used your brakes for a period of time, ceramic or semi metallic, you will feel a reduced braking ability for a split second no matter the material, I have felt it with cars that had semi metal pads and ceramic. I personally went back to the oem semi metal to have a better brake pedal bite and I've yet to over heat the sport package brakes so I prefer the more aggressive nature of the semi metallic, Il take the brake dust for a better feeling pedal.
#38
#39
superangrypenguin Yes that is true, that is the natural more aggressive nature of the semi metallic pads, its not like you loose complete brake feel with ceramic when cold, just a slight reduction on initial input. But if you drive hard and cook your semi metallic pads they that is far worse, hot metallic pads are worse then that slight initial brake pedal hesitation but that is on a track or if you drive hard and have 500+hp.. For our cars I've concluded that semi metallics are better since they give you better feel and you cant really get them hot on the streets, at least not the sport package brakes, I haven't felt the normal c class brakes which im sure aren't much bellow anyways.
#40
#41
Best?
There are tons of choices out there in terms of pads and rotors. Who knows what is best?
Last weekend I fitted fresh Pagid rotors to the front of our C300 and semi-metallic Centric pads at all four corners. I've been having really good luck with these pads. Fitting them to all our cars. Terrific stopping power under normal driving.
Premium rotors would be Zimmerman, which are often OE, and Brembo. However, there are many other good choices. Just do a search on Rock Auto and review all the options. Huge spread in pricing.
#42
The dust isn't bad with the semi-metallic compound. It's about 2/3 less than a traditional German brake pad we all can remember. The dust from the Centric is brown, it's not black. I can typically go a couple weeks without cleaning the wheels. However, once the dirty wheel has been in the rain, it looks pretty crappy.
#43
For those of you complaining about brake dust
I cannot recommend this enough:
https://www.autoglym.com/wheel-protector
Odd Piggy (03-22-2018)
#44
Looks like Auto Glym Wheel Protector is $27.95 on Amazon.
Also - the wheels on my 2013 C250 do not get nearly as dirty as those on my wife's 2015 GLK350. I asked at the local MB parts counter and was told that the front pads on my car are ceramic. They have plenty of initial bite. There is not much cold weather in my area, so I cannot comment on their cold performance. It may be worth asking at the parts counter if ceramic pads are available for other years and versions of the W204.
#45
Thanks to all for your responses, I am glad that I used the original MB pads.
Can anyone advise on my post #17 above? I still can't find nowhere the replacement decal plates.
#46
^These will work very well , here's my results ;
#47
The sticker that you are suggesting are made of soft vinyl (they can be glued on to the existing decals).
My original aluminum decals have the pins broken off. So I can't reinstall them back on to the caliper.
Hence I am looking for the replacement of the actual plates.
#48
My bracket was the same, hole in it and a pin missing. I used bondo to fill the hole, painted black, applied the sticker and finished it off with a clear coat. Its holding up quite well, I just used high temp silicone to stick the bracket to the caliper, some may say its a ghetto way but you will never know unless I told you and is holding up very well.
#49
My stickers arrived from Portugal (ebay). They're all separate letters, sort of a transfer system, not a single sticker. Not separating well from the liner meaning the letters are tearing. I don't think I'm even going to attempt it.
#50
That sucks, I would recommend the ebay link I have posted, they give you a bunch of different sizes and is a single sticker per logo, not per letter.. that sounds like a pain in the ***.
