W204 Some Issuses
W204 Some Issuses
the first:
have a w204 sedan, 2007 200cdi, amg optics, have switched backlight bulbs but still weak light on left.
But that's not the biggest issue, I also get error message on corner lighting and ILS, could it be fuses? It seems that both corners work fine when I start the car, so the xenon lights go up and down.
that's how it should be???
I had a similar problem and when I took out the bulbs, there were some damaged places on the plastic. The connections get melted over the time and it has to be replaced. I replaced the plastic part for $10-$15.
Connector problems
Contact lube may help, depending on the extent of contact damage. If replaced, be sure to use contact lube on the new pins.
Thnx for answer, its enough Change the black one?
[/QUOTE]
