HELP!!! w204 c200 cutting out
W204 c class
Started about 4 weeks ago on a hot day car get up to normal temp. Then cuts out had a mechanic look at it and it was it was doing it due to a leaking injector seal so I had all 4 replaced it only seems to do it on hot days I have replaced the thermostat and sensor and also had the rad flushed anybody have any ideas thanks in advance ...josh
Is the check engine light on? If not, you may want to still scan for codes since you might find one or more stored as "pending" even if the light is not on.
And it might help to get a better description of what "cutting out" means? Like what does it do? Does it stutter before it cuts out? Does it do it when idling, when stepping on the brakes? Do the dash lights come on when it dies or are they off?
W204 c class
There are no lights on it has also been plugged in and there are no codes, the temp light flashes on and car just cuts up it happens when driving and when stopped the temp of the car is normal and it will start back up straight away and run like normal once again (it only cuts out on hot days)
