Take a break warning message
When you first start driving the system measures how quick your steering inputs are. As you get tired your reaction changes for the worse nd the system alerts you. I believe it also takes into account the total amount of time spent driving in one shot and the time of day but I may be wrong here.
john1993 (08-13-2018)
superangrypenguin (08-13-2018)
The one and only time it has ever come on Interestingly on mine, it says "Drowsiness Detected" vs the OPs
I once took a break, went into a shopping centre, got out to find car quitted, sudden death stearing lock fail. I imagine if that should happen to you, you get a new car on the spot.
superangrypenguin (08-14-2018)
2013 W204
this has happens to me numerous times, even on a 2 hour drive. I think it just feels how you drive, so the slightest movement or change, this message will pop up. Always happens when I'm texting or driving with my knee when I'm eating, theres a lot of different ways it will trigger
for those you who have owners manual deficiency
So how does Mercedes-Benz Attention Assist work? Well, it all starts within a few minutes of entering the vehicle. Soon after drivers begin on their journey, the system creates an individual profile of the driver, recognizing behavior while the driver is fully alert. That profile is used as the basis for comparison during the rest of the drive.
Mercedes-Benz Attention Assist uses a highly sensitive sensor that monitors and records steering movement and speed. Research done by Mercedes-Benz showed that when drivers are fatigued, they will change their steering behaviors and make more errors, which are normally corrected quickly. When Attention Assist recognizes the vehicle drifting and being quickly readjusted back onto the center of the road or notices a change in driving behavior, it will go on to check several other parameters to see if the change is due to fatigue or other factors.
Attention Assist will examine considerations such as time behind the wheel, driver activity, weather, and road surface influences, and a variety of other factors that may be causing the irregular driving behavior. If the system determines drowsiness is the cause, it will send an audible and visible alert letting the driver know it’s time to take a break.
While Mercedes-Benz offers a number of technologies to help drivers be more aware of their surroundings, Attention Assist is the industry’s only technology that helps drivers monitor their own behavior.
The following 2 users liked this post by ChazThePhoenix:
aboutdamntime (08-17-2018),
superangrypenguin (08-17-2018)
