rear differential bearing sizes for 2010 C250 4matic
W204 C250 4Matic
I need to replace a failed bearing(s) in the rear differential of my 2010 C250 4matic. The only replacement kits I was able to find online were for 2009 E350 4matic and 2010 GLK 350 4matic. Does anybody know what bearing sizes or replacement kits will fit my wounded stallion?
Post your VIN and I'll see if the diffs are cross compatible between those models. Chances are they all use the same Timkin bearings.
W204 C250 4Matic
Here is my VIN WDDGF8FB4AF372501
Any help would be much appreciated.
olmi (10-04-2018)
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
The rear differential bearings seem to cost as much as a used diff. I don't see a point (in my case) of rebuilding then.
Both circa $230. Thoughts?
Why would yours be failing? It's not a common issue as far as I know.
Mine might be because I mighta smashed it a bit last winter...
W204 C250 4Matic
Just check online. Many complained about the very same problem with the diffs produced between 2008-2011 due to quality issues with the bearings.
00 C200 & 00 C55 & 06 SLK55
I remember my friend replaced his 2011 "Glk350 4-matic" diff. bearings year ago,
these bearings are the same with "W211 E350 4-matic" & "W207 E350 4-matic",,
*outer #: "211 350 02 49"
*inner #: "211 350 03 49"
-;ZAYED;-
-;ZAYED;-
W204 C250 4Matic
My friend confirm to me about fitment & he forward the part #s to me,,
i contacted to good E-Bay seller, who also confirm to me, these bearings will fit to:-
"W211 E350 4-matic" & "W204 E250/E300 4-matic" & "W207 E350 4-matic"..!
https://www.ebay.co.uk/itm/MERCEDES-...-/222623464689
-;ZAYED;-
-;ZAYED;-
W204 C250 4Matic
It generates high pitch sound and super annoying but doesn’t impact drivability.
That's all it takes huh?
Did you have any fragments in the oil?
How difficult was it to remove the diff/take it apart?
W204 C250 4Matic
It is dead, just compare it to the one at the bottom of the picture. My mechanic said he had to work hard to get to the bearings.
W207 differential
Does anyone know if the differentials on the e350 coupe change? Gear ratio? Mounting? CV axels? I found a 2010 and also a 2012 but my vehicle is a 2011, can someone please guide the right direction with this?
Here is my VIN: WDD2042821F612921
Thanks for your help in advance.
