Voltage and Amp Problem
Old 03-24-2019, 11:32 PM
DomDworaczek's Avatar
C300
Hey i thought i had a problem with the alternator on my c300 i would get a battery light and command shutting off and my fan would stop blowing i check my voltage and amps and my amps would go -50 and never go up and my volts would go down but occasionally my amps reach +50 and my volts would charge up anyone know what the problem is its not the battery or alternator any help?
Old 03-25-2019, 12:13 PM
tekfoc's Avatar
18 E63S
Voltage regulator on alternator
80.00 dollars for part.
May not be the exact year of your car but gives you an idea
https://www.mbpartsdepot.com/oem-par...Y2LWdhcw%3D%3D
Old 03-30-2019, 08:09 PM
C300
That was no the problem changed the voltage regulator and alternator and still having the same problem please help
Old 03-30-2019, 09:32 PM
tekfoc's Avatar
18 E63S
Have the negative cable to battery tested it has a built in regulator also could be faulty .
Old 03-30-2019, 09:33 PM
C300
You don’t think it could be the Sam module
Old 03-30-2019, 09:45 PM
tekfoc's Avatar
18 E63S
this will give you an explanation how sams work and types of issues you will have if it were Sam related .
https://www.benzworld.org/forums/w22...topics/1644809
Old 04-19-2019, 05:01 PM
C300
Yeah I’ve test everything and no the car completely died won’t turn over or anything lights and dash come on brand new battery brand new alternator do you think a fuse went in the positive battery fuse box
Old 04-19-2019, 05:44 PM
tekfoc's Avatar
18 E63S
It's the negative cable it has a voltage smart regulator attached
When sensor is bad it doesn't send a signal to alternator regulator to turn on,
Which causes battery to run down.
Old 04-19-2019, 06:04 PM
C300
How do you test to see if it’s bad
Old 04-19-2019, 07:37 PM
tekfoc's Avatar
18 E63S
use a voltage multimeter and measure charging voltage
it should be anywhere between 14.5 to 14.8 when properly charging .
atached multi meter on to negative cable for reading
Old 04-19-2019, 07:38 PM
C300
The.car won’t start and it’s not charging
Old 04-19-2019, 10:17 PM
tekfoc's Avatar
18 E63S
if the battery is dead recharge battery and try to start
if battery is fully charged then you have other major issues going on .
As you stated earlier check fuses.
EIS ISSUES POSSIBLY.
C300
I did nothing
Old 04-19-2019, 10:34 PM
tekfoc's Avatar
18 E63S
I did nothing
sorry guy sos time. get-someone that can go over it.
Too many probable causes now to give you accurate help with out me physically being there.
Old 04-22-2019, 08:54 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Check every single ground point on the underside of the vehicle for corrosion/greening copper. Ground points screwing up will really mess with the electrical
Old 09-20-2020, 12:58 AM
Hariandja's Avatar
C200 W204 Year 2012
I think I have similar issue.
After reading all the threads, I could not see what is the solution on this issue.
Someone could share it with me, please.
Thank you very much.
Measurement:
Mine is MB C200 W204 Year 2012 (engine M271)
I turned on the fancy feature to monitor the Voltage and Current on the dashboard:
- Initial battery voltage: 12.4V (I use new AMARON battery in July 2020)
- A while after starting the engine, the voltage drop to 11.1 V for ver short time( I think this is normal)
- Afterward, the voltage increase and reach 14.8V (current 19 A)
- I start to turn on the radio, AC, and finally all lights, the voltage drop to 13.1 V (current drop to 3A)
- Shift the automatic tranmission lever from P to R, the voltage drop to 12.8 V (current drop to -5.5A)
- Shift again the automatic transmission lever from R to N, the voltage increase to 13.V (the current going up to 9A)
- Shift again the automatic transmission lever from N to D, the voltage showing 13 V (the current drop to 2A)
- Shift back again the automatic transmission lever from D to P, the voltage showing 13.6 V (the current drop to 10A)
After driving the car for about five minutes, the red engine warning light flashing and later car stall
After turn off everything, I ignite again and the engine is OK.
But the car will stall again after driving a while (like 5 minutes).
Do I need to replace the alternator for sure?
Thank you
Old 09-20-2020, 01:13 AM
Hariandja's Avatar
C200 W204 Year 2012
Couldnt understand on your direction.
how could measure on negative port only?
Quick Reply: Voltage and Amp Problem
