Replacement of Rear SAM Plugs
Hello everyone.
I have a C350 sedan, I was involved in an accident and the rear sam connectors were damaged.
Is it possible to buy and replace such connectors?
Regards
Regards
'99 and '05 E55 AMG
Available from the dealer although it will most likely be a special order. The electronic parts catalogs shows connectors and pins/sockets under the electrical harness section. Assuming you are talking about the harness and not the sockets of the SAM itself. In that case, find a bad SAM and swap its sockets over to your SAM while ensuring all the pins are put back into the same location.
